Cleanup.bat Configuration Questions
Greetings everyone,
When running the cleanup.bat process, is it supposed to follow the configuration rules set in the server configuration or is there somewhere else to configure the rules. My server is set to the following backup rules, incremental files backups min 2/max 15, full file backups min 1/max6.
When running the cleanup.bat process, I see:
Client with id=xxx has 2 full file backups max=1
Client with id=xxx has 2 incremental file backups max=2
Shouldn’t the max for each of those reflect what is set in the server configuration? If I run the cleanup.bat to completion, I will lose all of my incremental backups. Is this the intended operation of the cleanup.bat process or should I be doing something different to cleanup my backups? It seems as though the normal scheduled cleanup is not working properly because I have clients with more backups then my configured max full/incremental settings.
-Thanks-
From my short testing with Full Backup it seems that it does follow those rules
I had Max set on 5 Min set on 2
ran a few manual backups got it up to 6 - ran the manual cleanup and it cleared 1 backup
However I am too struggling with the auto cleanup I’m not sure whats triggering it
time was set correctly, configured Max and Min files to keep, even played with the Quota reducing it to 20% the only thing I haven’t tried is playing with the Archive
