I am trying to find out if there is way to change client settings after having deployed the client.
Here is a more detailed situation:
I have a freshly installed version of UrBackup (2.4.x) and I didn’t change any settings at all. I then proceed to add two Linux clients with the the button “Add new client”, download the client for Linux afterwards and install it. If I change client specific settings, like “Interval for incremental backups” and also disable the global option “Allow client-side change of settings” as well as per client, will the new interval be set for the clients, or do I have to reinstall the clients?
Is there another way to change the client settings instead of reinstalling them with the aforementioned settings disabled?
Thanks in advance.
