Ok, I have read the manual, installed the client using the OpenSuse Link. But the manual suggests creating a file in a random place based on what I can see. The folder structure was not created by the install.
So the manual echo’s information to /usr/local/var/urbackup/data/settings.cf
which I have done.
but on running start_urbackup_client --loglevel debug --no_daemon --internetonly
it reported Internet mode is not enabled.
So where are you meant to put your configuration file on a centos 6.7 install?
Thank you.
I know this has been a while to return, however once I manually added the client, and downloaded the installer from the server, everything went much better. This is the correct location of the file.
