Centos 6.10 i686 client fails after update
This system has been running for a long time until the latest update to:
urbackup-client-nogui-1.4.11-3.3.i686
in debug mode i get the following error in logs:
2019-10-08 09:21:58: rc=0 hasError=true state=0
2019-10-08 09:21:58: ClientService cmd: #IyDMzPtlLiKt1Cz8YvzDK#INCRINTERVALL “64803”
2019-10-08 09:21:58: ClientService cmd: #IyDMzPtlLiKt1Cz8YvzDK#VERSION 248
2019-10-08 09:21:58: ClientService cmd: #IyDMzPtlLiKt1Cz8YvzDK#2LOGDATA 1570517166 0-1570517156-Starting unscheduled incremental file backup…
2-1570517157-Constructing of filelist of “xxx.xxxx.com” failed - TIMEOUT(1)
2-1570517166-Backup had an early error. Deleting partial backup.
Downgrading to an older version of client and everything works again.
Any ideas?
markl
Ok, “update to latest”. Which version are you running and what version doesn’t work (output of urbackupclientctl --version if that one is present…)?
Hi
Thanks for the response, Excellent software!
The version that does not work is: UrBackup Client Controller v2.4.8.0
System was working until the most recent automatic update, server is set to update clients.
Update seems to have occurred on October 5 or 6 and backups failed from that date, server does not seem to have any log information on updates performed.
Not sure what the version before that was as it has now been replaced, do you have a location where i can download the previous version?
Also tried yum reinstall of the latest version, no errors in yum reinstall.
They system is currently running 1.4.11 as it is the only old version i have.
Just tried to run v2.4.8.0 in foreground and it failed with Core Dump
2019-10-12 03:39:22: Final path: /sbin/ifdown
2019-10-12 03:39:22: Final path: /sbin/ifup
2019-10-12 03:39:22: Final path: /usr/lib/jvm/java-1.6.0-openjdk-1.6.0.41/jre
2019-10-12 03:39:22: Final path: /usr/lib/jvm-exports/java-1.6.0-openjdk-1.6.0.41
Illegal instruction (core dumped)
Regards
markl
Might be the same issue as here: [Ubuntu] Glibc not installed or too old (CPU has no SSE4 instructions + it uses the Android binary).
You can either install the version from there, or run client 2.3.x from here https://hndl.urbackup.org/Client/2.3.4/index.html
Hi
Glibc is installed,
Version is: glibc-2.12-1.212.el6_10.3.i686
Installed Client version 2.3.4 and backups working properly.
Can i assume you will no longer be supporting updates to older systems?
Server is Hp DL380 Intel CPU X 2 with 4 cores
processor : 3
vendor_id : GenuineIntel
cpu family : 15
model : 2
model name : Intel® Xeon™ CPU 3.06GHz
stepping : 9
microcode : 45
cpu MHz : 3066.590
cache size : 512 KB
physical id : 3
siblings : 2
core id : 0
cpu cores : 1
apicid : 7
initial apicid : 7
fdiv_bug : no
hlt_bug : no
f00f_bug : no
coma_bug : no
fpu : yes
fpu_exception : yes
cpuid level : 2
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe pebs bts eagerfpu cid xtpr pti retpoline
bogomips : 6101.00
clflush size : 64
cache_alignment : 128
address sizes : 36 bits physical, 32 bits virtual
power management:
Regards
markl
