Is there a way to distribute the cbt drivers separately alongside the client?
I saw that after purchasing the license, we would be brought to a download page to download the various versions of the client with cbt compiled in.
I can give you the changes to the installer scripts. Do you use the NSIS(exe) or MSI installer?
I am using Nsis. Do you mean that the cbt driver is added into the nsis or msi installer as a separate package and is not compiled into the source code?
Yes, it is separate. That is why you can for example install the latest beta client ( UrBackup Server 2.2.0 beta/Client 2.2.0 beta/Restore 2.2.0 beta ) over a CBT client and it’ll work.
I see. Thank you! In that case may I see the changes to the Nsis installer script?
installer.patch (2.9 KB)
