Case sensitive server OS
I installed urbackup server in docker on raspbian and do get the following error message:
(err_file_system_case_insensitive). File exists (code: 17)UrBackup Server is running on a operating system where file systems are usually case sensitive. Work-arounds for UrBackup to work with case insensitive backup storage are disabled.The backup storage is case insensitive, however. This might cause issues.
I cannot find any work-arounds. What can I do?
What storage are you using?
Workarounds or complete fixes depend on the answer.
Hi @Bearded_Blunder,
Thanks for your answer.
I use a usb mounted hdd with a vfat filesystem:
UUID=2FB4-XXXX /mnt/hdd vfat defaults,auto,users,rw,nofail,umask=000 100 0
Then the easy fix is to re-format it ext4 or something Raspbian knows & likes.
Personally I’d delete whatever partition it has & start over, but that may be overkill.
