I just looked in the backup files for the data belonging to a client that is backing up just fine.
I can see and even open the files from the web interface but the client has no folder of it’s own in the urbackup file structure.
The client has almost 700GB of data backed up.
How is this possible?
The authentication error is because the client is suffering from a drive failure. Hence the need to pull files from the server.
I need to pay them a visit tomorrow and have the data with me.
I am currently downloading from the web interface but not sure it’ll work as it’s a huge ZIP file. I am using latest beta server so hopefully it will be ok.
Server is running in a FreeNAS Jail and the path is mapped to a folder in the ZFS Pool.
Could be some kind of symbolic link following problem if it works on the web interface. Maybe you could browse into it on the console and look at it with ls -lh. If you are accessing it via samba try looking at it with the samba user in the jail samba runs in.
I’ve tried finding it via SSH and the root user. Everything else is there but not the client I need.
I can’t restore via the web interface. I have tried it on a new client (in a VM) it looks like it’s going to work but then does nothing. I can select individual files and they open perfectly.
I’m not sure why the original download was truncated. It was surprisingly slow to download 51GB over Gigabit Ethernet. Maybe an hour in total. SMB would have been transferred in seconds. So maybe it was just interrupted.
The folder starting ? is very odd. It is still functional and now backing up the repaired remote client.
Can I query the database and find the path from there? Maybe that will give me a clue.
Update: I just had to remotely reinstall the client as it was showing authentication failure on the server status page.
I copied the computer name field from the client and pasted it into a hex editor.
