Using UrBackup 2.3.8 installed on Windows.
According to the server admin manual you can add virtual subclient names after which additional clients should show up in the form client1[subclientname].
I have enabled “different settings for this client”, then added 3 virtual client names in the form
sub1|sub2|sub3
That is exactly what the manual says. However, no new client names are showing up anywhere. I also restarted the server just to be sure, nothing happens.
What else do I need to do?
