Hi to all I just upgraded debian 10 to 11 and I cannot access anymore urbackup GUI.
If I try
root@backup:/home/user# systemctl status urbackupsrv
● urbackupsrv.service - LSB: Server for doing backups
Loaded: loaded (/etc/init.d/urbackupsrv; generated)
Active: active (exited) since Thu 2022-01-13 18:56:35 CET; 13min ago
Docs: man:systemd-sysv-generator(8)
Process: 474 ExecStart=/etc/init.d/urbackupsrv start (code=exited, status=0/SUCCESS)
CPU: 91ms
gen 13 18:56:35 backup systemd[1]: Starting LSB: Server for doing backups...
gen 13 18:56:35 backup systemd[1]: Started LSB: Server for doing backups.
or
root@backup:/home/user# systemctl status urbackupclientbackend
● urbackupclientbackend.service - UrBackup Client backend
Loaded: loaded (/lib/systemd/system/urbackupclientbackend.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2022-01-13 18:56:35 CET; 15min ago
Main PID: 418 (urbackupclientb)
Tasks: 10 (limit: 2333)
Memory: 30.0M
CPU: 105ms
CGroup: /system.slice/urbackupclientbackend.service
└─418 /usr/local/sbin/urbackupclientbackend --config /etc/default/urbackupclient --no-consoletime
gen 13 18:56:35 backup systemd[1]: Started UrBackup Client backend.
gen 13 18:56:34 backup urbackupclientbackend[418]: ERROR: urbackupserver: Creating v6 SOCKET failed
gen 13 18:56:34 backup urbackupclientbackend[418]: ERROR: FileSrv: Failed setting SO_REUSEADDR in CUDPThread::CUDPThread
gen 13 18:56:34 backup urbackupclientbackend[418]: ERROR: Binding ipv6 UDP socket to port 35622 failed
so in dmesg I got this error related to libcrypto
urbackupsrv[548]: segfault at 10 ip 00007f220bac5fe0 sp 00007ffc539fa0d0 error 4 in **libcrypto++.so.8.4.0**[7f220b99c000+1e6000]
maybe is something related to libcrypto8, I checked that in debian 10 was version 6. Is there a way to fix this? I have installed urbackup from this repository:
root@backup:/etc/apt/sources.list.d# cat home:uroni.list deb http://download.opensuse.org/repositories/home:/uroni/Debian_11/ /
