The headless client successfully builds and runs on FreeBSD using the configure options “–enable-headless” and “–enable-embedded-cryptopp”.
I’m working on creating a port, but I am unable to get the client to build using FreeBSD’s own cryptopp port. FreeBSD frowns on ports using bundled libraries unless absolutely necessary (https://www.freebsd.org/doc/en_US.ISO8859-1/books/porters-handbook/bundled-libs.html).
When you remove the “–enable-embedded-cryptopp” configure option the build errors trying to find a cryptopp header file:
In file included from Server.cpp:44:
./md5.h:124:10: fatal error: ‘cryptopp/md5.h’ file not found
The file md5.h does exist, under /usr/local/include/cryptopp/. I can get the build to proceed further by adding “–with-crypto-prefix=/usr/local/include/cryptopp”, but it then errors finding libcryptopp.a:
c++: error: no such file or directory: ‘/usr/local/include/cryptopp/libcryptopp.a’
The libcryptopp.a does exist, but it’s under /usr/local/lib/.
Any suggestions?
Note that the server builds fine with FreeBSD’s own cryptopp port. I’ve already submitted a port for the server: https://bugs.freebsd.org/bugzilla/show_bug.cgi?id=225148
