jarno
June 5, 2018, 11:31am
#1
It seems there is a bug in the way urbackup server tests access to the backupfolder.
I would like to set urbackup backupfolder as /home/backup/urbackup
root@host (0)# ls -ld /home
drwxr-xr-x 1 root root 134 Jun 5 19:07 /home
root@host (0)# ls -ld /home/backup
drwxr-x— 1 root backup 25724 Jun 5 19:07 /home/backup
root@host (0)# ls -ld /home/backup/urbackup
drwx------ 1 urbackup urbackup 50 Jun 5 19:08 /home/backup/urbackup
User urbackup belongs to group backup
root@host (0)# groups urbackup
urbackup : urbackup backup
root@host (1)# sudo -u urbackup touch /home/backup/urbackup/permission_test
root@host (0)# ls -l /home/backup/urbackup /
total 0
-rw------- 1 urbackup urbackup 0 Jun 5 19:18 permission_test
/var/log/urbackup.log:
2018-06-05 19:25:52: ERROR: Cannot open “/home/backup”: Permission denied (13)
2018-06-05 19:25:52: ERROR: Cannot open “/home/backup/urbackup”: Permission denied (13)
If I use folder /home/urbackup as backupfolder, and /home/urbackup is owned by urbackup:urbackup it works OK.
Maybe the permission testing is bit off? I noticed someone else had the same issue earlier, but no one answered him.
Server host is running: Ubuntu 16.04.4 LTS (GNU/Linux 4.4.0-127-generic x86_64)
urbackup version is: 2.2.11.2193-1ubuntu1~xenial
MK05
June 5, 2018, 11:59am
#2
Change the permission on the parent directory /home with recursive permission. This should work.
jarno
June 5, 2018, 12:22pm
#3
urbackup can access /home
it cannot access /home/backup even the urbackup-user has read/execute rights to the directory and the sudo command works all fine. It is urbackup-server issue. It is testing directory permissions in some weird way.
MK05
June 5, 2018, 12:26pm
#4
U need to give urbackup user permission for
Change the permission and this will work for you.
jarno
June 5, 2018, 12:30pm
#5
But urbackup user has already full rwx user-permissions to the /home/backup/urbackup directory. urbackup-server log complains about the /home/backup folder to which urbackup-user has rx-permissions through backup-group membership.
MK05
June 5, 2018, 12:32pm
#6
it should have rwx permission.
MK05
June 5, 2018, 12:36pm
#7
sudo chown -R urbackup:urbackup /home/backup/urbackup
sudo chmod -R 777 /home/backup/urbackup
jarno
June 5, 2018, 1:25pm
#8
I am sorry, but you are misunderstanding the issue. The problem is access to the folder /home/backup to which user “urbackup” has rx permissions through “backup”-group membership.
