Both Urbackup Server and Veeam Backup are installed on the same physical server.
Veeam Backup Jobs failed. We opened a case to veeam and they said TCP 6160 port is used by another application. We checked with the command “nbstat -bone”. Urbackup is also using same port. What is this port used for? Can we change this port with another one?
UrBackup is using those ports: https://www.urbackup.org/administration_manual.html#x1-9000010.3 Not 6160
Thank you very much
