HI
i was wondering if someone could shed some light, Currently using restic for backups on my linux servers, but as restic is complicated on a windows server i wanted to implement a better solution, I was looking at urbackup and working really nice,
I was wondering whats the rule with the full backups and the incremental? As on restic it always incremental after the first full, should i keep that same scheme? or do a full every now and then?
Thank you
Sure, file backups can be always incremental, whereas image backups should be always incremental only when using the “Raw copy-on-write” file format.
With btrfs UrBackup can also use a special raw image file format. This format has no size limitation and allows for an “incremental forever” style image backup. (source)
thanks for the reply, so its possible to only do on full backup of the files and never again? just incremental
ex: do a full backup day 1 then incremental every day 90 days,
on the 91 day, deletes the 1st incremental backup
Correct. This is how I’ve set it up myself.
