Hi
Totally new to urBackup, and any backup methods and strategies overall, so bear with me please.
I installed urbackup server as a docker container in my ubuntu server and the client on my Windows 10 machine. Everything ok on the server side.
I then installed the client program on my Windows and this window popped up at the startup:
I seletcted Manually select the files to backup and Manually list the volume to backup
As for the second option, I didn’t want to make any disk/partitions backup, just folder, so I would’ve been more than happy just with the first option, but I had to choose one nonetheless.
It then started the partition backup that I stopped after a while since I have no need for that, now at least.
I had to run the folder backup process again and it went well:
So, how can I disable partition/image backup?
