Backups were failing - after looking at permissions I found issues with some fuse mounts that root can’t read.
I tried excluding “thinclient_drives” and “thinclient_drives” but it still fails.
thinclient_drives is mounted when terminal server clients connect with the RDP protocol.
Workaround is to unmount the directory with fusermount -u thinclient_drives
I’m waiting for the backup to finish, before unmounting it was failing within a couple of minutes.
Wondering if there’s a better way to skip these user mount points
xrdp-chansrv on /home/someuser/thinclient_drives type fuse.xrdp-chansrv (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
Starting unscheduled full file backup...
Creating snapshot of "/home" failed
Calculated size of logical volume is 0 extents. Needs to be larger.
Creating snapshot of "" failed.
Error while listing files in folder "/home/someuser". User may not have permissions to access this folder. Errno is 2
Indexing files failed, because of error
Constructing of filelist of "myserver" failed: error - index error
Backup had an early error. Deleting partial backup.
