Can not determine what the problem is in the client or the server?
Configured zfs in accordance with the documentation
urbacku-server is started from root
When choosing RAW copy-on-write i was get error:
Server Ubuntu 16.04
Client Windows 2.1.16
root@plt-backup:~# apt show urbackup-server
Package: urbackup-server
Version: 2.1.19.1765-1ubuntu1~xenial
root@plt-backup:~# cat /etc/default/urbackupsrv
# Defaults for urbackupsrv initscript
# sourced by /etc/init.d/urbackupsrv and /lib/systemd/system/urbackup-server.service
# installed at /etc/default/urbackupsrv by the maintainer scripts
# This is parsed as a key=value file
FASTCGI_PORT=55413
HTTP_SERVER="true"
HTTP_PORT=55414
LOGFILE="/var/log/urbackup.log"
LOGLEVEL="warn"
DAEMON_TMPDIR="/tmp"
SQLITE_TMPDIR=""
BROADCAST_INTERFACES=""
USER="root"
cat /etc/urbackup/backupfolder
/mnt/services/SYSTEM/urbackup
cat /etc/urbackup/dataset
hdd/local/SYS/urbackup
root@plt-backup:~# zfs list -r hdd/local/SYS/urbackup
NAME USED AVAIL REFER MOUNTPOINT
hdd/local/SYS/urbackup 5,06G 624G 5,06G /mnt/services/SYSTEM/urbackup
hdd/local/SYS/urbackup/alexandriya-wycon-nebo-kassa 96K 624G 96K /mnt/services/SYSTEM/urbackup/alexandriya-wycon-nebo-kassa
2017-11-01 03:07:30: ERROR: Backing up System Reserved (SYSVOL) partition failed. Image backup failed
2017-11-01 03:07:30: ERROR: Backup failed
In client log
Starting scheduled full image backup of volume “C:”…
Time taken for backing up client alexandriya-wycon-nebo-kassa:
Backup failed
root@plt-backup:~# urbackup_snapshot_helper test
Testing for btrfs...
ERROR: not a btrfs filesystem: /mnt/services/SYSTEM/urbackup/testA54hj5luZtlorr494
Testing for zfs...
ZFS TEST OK
I have no idea what else to check
