Can anyone tell if it is possible to set up more than one destination for backup?
Thanks.
Thanks.
As folder destination, no. Because of dedup/hardlink , al the files have to be on the same filesystem
As backup server, yes, you can have a client backup to multiple servers, and each servers may backup to a different filesystem.
Please search the forums a bit on how to do it.
Check this link if you meant remote and local backups.
