Can I use Smb resource in Backup storage path?
Smth like smb:\192.168.1.1\Backups
If it’s linux, you will need to mount the samba drive separately and then you can put in the path like normal.
If it’s windows, mount it separately as a shared drive (eg z:) and then you can put in the path like normal. z:\pathname\
