I wrote a Check_MK plugin for Urbackup (https://github.com/edvler/check_mk-urbackup-check).
The plugin uses the API-wrapper to get the status of all hosts (https://github.com/uroni/urbackup-server-python-web-api-wrapper).
My current problem is that the API reports only the status of the host. If a host has multiple drives attached (maybe c:,d:,e:,f:,g:) the api returns OK if only one image backup (e.g. c:) succeeded.
The problem: It’s possible that only one drive is backuped and all the other drive never gets backuped and the host is reported as OK.
How can i query the status of each drive letter configured in Urbackup for a host?
Greets
Matthias
