Backup not working
Trying to backup one client since two weeks with no success - backup is always being killed at completion. Some files are taken away in the middle of the backup run by Security scanner as documented by Scanner log. Based on that the error messages 'Files missed" are ok - are exactly the files the virus scanner had killed.
However - always after backup completon an error message is displayed saying backup had errors and the complete (and really fully complete) Backup is deleted. As a result a backup is not possible.Can’t believe that UrBackup still runs for more than 12 hours to react on the missed files - looks like there is an error which is not reported. Event log shows no error message indivating an issue in the relevant time window.
Checked recorded events - no error reported there fitting with Urbackup failure report time. Checked filesystem with chkdsk with correction - reports ok /as expected, disk is new. Also checked disk with seatools - no issue as expected.
Appreciate some help what might cause the issue.
Cllient is a little bigger - roughly 450.000 files, about 950 Gig Space usage.
Thanks for help. Server log is copied below for Info.
Level Zeit NachrichtInfo
22.01.15 21:05Starting full file backup…
Info 22.01.15 23:15Indexing of “C” done. 46354 filesystem lookups 0 db lookups and 0 db updates
Info 22.01.15 23:15Indexing of “D” done. 2763 filesystem lookups 0 db lookups and 0 db updates
Info 22.01.15 23:15Indexing of “M” done. 21 filesystem lookups 0 db lookups and 0 db updates
Info 22.01.15 23:15Indexing of “K” done. 902 filesystem lookups 0 db lookups and 0 db updates
Info 22.01.15 23:15Papa-PC: Loading file list…
Info 22.01.15 23:15Papa-PC: Started loading files…
Fehler 23.01.15 06:32Error opening file “g:\UrBackup\urbackup_tmp_files\209356” from pipe for reading file. File: temp_fn ec=2
Fehler 23.01.15 06:32Error opening file “g:\UrBackup\urbackup_tmp_files\209358” from pipe for reading file. File: temp_fn ec=2
Fehler 23.01.15 06:32Error opening file “g:\UrBackup\urbackup_tmp_files\209366” from pipe for reading file. File: temp_fn ec=2
Fehler 23.01.15 06:32Error opening file “g:\UrBackup\urbackup_tmp_files\209368” from pipe for reading file. File: temp_fn ec=2Fehler
23.01.15 06:32Error opening file “g:\UrBackup\urbackup_tmp_files\209370” from pipe for reading file. File: temp_fn ec=2
Fehler 23.01.15 06:32Error opening file “g:\UrBackup\urbackup_tmp_files\209372” from pipe for reading file. File: temp_fn ec=2
Fehler 23.01.15 06:32Error opening file “g:\UrBackup\urbackup_tmp_files\209374” from pipe for reading file. File: temp_fn ec=2
Fehler 23.01.15 06:32Error opening file “g:\UrBackup\urbackup_tmp_files\209376” from pipe for reading file. File: temp_fn ec=2
Info 23.01.15 22:21Waiting for file transfers…
Info 23.01.15 22:51Writing new file list…
Info 23.01.15 22:51Waiting for file hashing and copying threads…
Info 23.01.15 22:51Transferred 946.274 GB - Average speed: 95.6814 MBit/sFehler23.01.15 22:51FATAL: Backup failed because of disk problems
Fehler 23.01.15 22:51Backup had errors. Deleting partial backup.
Warnungen 24.01.15 00:29Exponential backoff: Waiting at least 40m before next file backup
Disable your virus scanner for g:\UrBackup ?
Finally found the Issue. Client had a hidden Virus Vault which wasn’t excluded from Backups. Taking it off cleared the issue for now.
However, loosing a full backup due to a few infected files is not optimal and error messages do not alow to identify the client source file location. Probably not a major issue, but worth to keep in mind.
