We have an Ubuntu Server that we would like to use for Urbackup. We have two raids setup, a raid 1 with two SAS drives, and a raid 10 with 6 SATA drives. The OS is installed on the raid 1. How do I setup the backups to be stored on the raid 10 virtual drive?
Can you not set the backup directory - inside the web-interface - to your mount point?
Sorry for the long reply… Yes I can, I was just new to the situation. Was able to set the mount point, give the correct permissisons, then set the location for the backups!
