Newbe to UrBackup and Linux so be gentle–do know windows though… Trying to setup a NAS on a RaspberryPi 3+ with openmediavault as the OS. Installed UrBackup on the raspberrypi. When I set the path for the backup, I received the following error:
The directory where UrBackup will save backups is inaccessible. Please fix that by modifying this folder in ‘Settings’ or by giving UrBackup rights to access this directory. (err_folder_not_found). No such file or directory (code: 2)
Detailed error info:
Can access /
Cannot access /raspberrypi. No such file or directory (code: 2)
Cannot access /raspberrypi/backupA. No such file or directory (code: 2)
Pretty sure it is an permissions issue in openmediavault but I have spent a day and half trying to get it to work with no luck. The funny thing, I can backup to the Raspberrypi via Handybackup on our win server 2012 without problems. Running server 2.2.11 and client 2.2.6
