Hi All,
I use Urbackup since one years for save all data in my company.
Recently i’ve setting the security setting on my debian Backup server.
For this reason i’ve add the rules on iptables, set sudo and create admin account and install portsentry.
Just after that, all backup no longer worked
I’ve check all the rules but i’ve a same issue each time i want to start a backup
Server : Debian 7
Windows server : Win 2008, 2012 and 2016
Urbackup srv version : 2.2.10
Urbackup client version : 2.2.6
Iptables rules for Urbackup :
#UrBackup iptables -t filter -A OUTPUT -p udp --dport 35623 -j ACCEPT iptables -t filter -A INPUT -p tcp --dport 55413 -j ACCEPT iptables -t filter -A INPUT -p tcp --dport 55414 -j ACCEPT iptables -t filter -A INPUT -p tcp --dport 55415 -j ACCEPT
Firewall rules for each clients :
Clients logs :
2018-08-30 01:02:28: ERROR: FileSrv: Could not open file \?\F:. Le processus ne peut pas accéder au fichier car ce fichier est utilisé par un autre processus. (code: 32)
2018-08-30 15:34:19: ERROR: Recvfrom error in CUDPThread::UdpStep
2018-08-30 15:34:19: ERROR: Last error: 10058
2018-09-03 10:57:34: ERROR: Recvfrom error in CUDPThread::UdpStep
2018-09-03 10:57:34: ERROR: Last error: 10058
2018-09-03 13:26:33: ERROR: Recvfrom error in CUDPThread::UdpStep
2018-09-03 13:26:33: ERROR: Last error: 10058
Server logs :
2018-09-03 13:33:14: ERROR: Backing up System Reserved (SYSVOL) partition failed. Image backup failed
2018-09-03 13:33:14: ERROR: Backup failed
2018-09-03 13:33:15: ERROR: Sending broadcast failed!
2018-09-03 13:33:15: WARNING: Exponential backoff: Waiting at least 40m before next image backup
2018-09-03 13:33:25: WARNING: Connecting to ClientService of “TOUSRVC10” failed: Sending logdata to client failed
2018-09-03 13:33:46: ERROR: Connecting to ClientService of “Rip-Xitron” failed: Getting MBR for drive SYSVOL failed
2018-09-03 13:33:56: ERROR: Connecting to “Rip-Xitron” for image backup failed
2018-09-03 13:33:56: ERROR: Error opening file ‘/media/TOUNAS02/BACKUPS/HP-ESKO6800-2/171015-2046_Image_SYSVOL/Image_SYSVOL_171015-2046.vhdz’
2018-09-03 13:33:56: ERROR: Error opening file ‘/media/TOUNAS02/BACKUPS/HP-ESKO6800-2/171015-2047_Image_C/Image_C_171015-2047.vhdz’
2018-09-03 13:33:56: ERROR: Error opening file ‘/media/TOUNAS02/BACKUPS/HP-ESKO6800-2/171015-2153_Image_D/Image_D_171015-2153.vhdz’
Nmap :
Starting Nmap 6.00 ( http://nmap.org ) at 2018-09-03 16:03 CEST
sendto in send_ip_packet_sd: sendto(4, packet, 28, 0, 10.30.0.117, 16) => Operation not permitted
Offending packet: UDP 10.30.0.122:34771 > 10.30.0.117:35623 ttl=55 id=35047 iplen=28
Offending packet: UDP 10.30.0.122:34772 > 10.30.0.117:35623 ttl=38 id=17160 iplen=28
Nmap scan report for 10.30.0.117
Host is up (0.00027s latency).
PORT STATE SERVICE
35623/udp open|filtered unknown
MAC Address: 80:18:44:E2:51:60 (Unknown)Nmap done: 1 IP address (1 host up) scanned in 0.41 seconds
For the moment if i stop firewall on debian server i can backup all the client
Have you an idea where the problem come from ? I’ve forgot to add a port in iptables rules ?
Thank’s for your help
