Can you check on the client if there are any disk errors in the system log? Also try running a chkdsk on the client to see if any problems are reported.
The somewhat general “disk error” is usually described by some earlier error message. Can you post all (warnings and errors) log messages of the failed backup?
Log (Narayanappa)
Level Time Message
Errors
09.04.14 10:20
Connecting to ClientService of “Narayanappa” failed - CONNECT error during filelist construction
Errors
09.04.14 10:20
Backup had errors. Deleting partial backup.
Back
Log (Narayanappa)
Level Time Message
Info
09.04.14 10:20
Starting full file backup…
Errors
09.04.14 10:20
Errors
09.04.14 10:20
I have the same problem on a lot of client over internet
I work on 1.3.2 urbackup server and 1.3.1 on client
Erreurs
15.04.14 19:54
Connecting to ClientService of “laure” failed - CONNECT error during filelist construction
Erreurs
15.04.14 19:54
[quote=“charlymd”]
15.04.14 19:54 Connecting to ClientService of “laure” failed - CONNECT error during filelist construction [/quote]
This error is most of the time caused by the client going offline. UrBackup Server 1.4 will not create a separate log for that error. For now you’ll just have to ignore it in this case.
As indicated, I have checked the system log and also chkdsk run. Everything is normal. Still this backup failed - disk error ; deleting partial backup is coming. Pl find below the error
Errors 24.04.14 12:01 Error opening file “C:\Windows\TEMP\urbackup_tmp\urb7A79.tmp” from pipe for reading file. File: temp_fn
Errors 24.04.14 12:07 Error opening file “C:\Windows\TEMP\urbackup_tmp\urb5DC6.tmp” from pipe for reading file. File: temp_fn
Errors 24.04.14 12:38 FATAL: Backup failed because of disk problems
Errors 24.04.14 12:38 Backup had errors. Deleting partial backup.
Haven’t seen this error before. Could occur because of one of the following:
[list]
[:8uoriclv]There is a program/process deleteing temporary files. You can change the temporary file folder in the settings.[/:8uoriclv]
[:8uoriclv]There is a race condition in the temporary file creation. I’ll look into this. [/:8uoriclv]
[:8uoriclv]The API seems to be limited to 65,535 files. So something could happenif this limit is reached.[/:8uoriclv]
[/list:u:8uoriclv]
The issue should go away if you disable “Use temporary files as file backup buffers” in the advanced settings.
