I have a 4TB backup drive connected to urbackup.
/dev/sda1 3.7T 3.6T 4.1M 100% /mnt/backupserver
The 4TB disk is completely full but urbackup only knows about 2TB for some reason. Remove unknown doesn’t seem to help either.
urbackup-remove-unknown-2026-04-26.log.gz (5.3 MB)
Any ideas?
Ncdu reports no usage (as expected due to btrfs)
ncdu 1.19 ~ Use the arrow keys to navigate, press ? for help
--- /mnt/backupserver/urbackup --------------------------------------------------------------------------------------------------------------------------------------------------------------------------
. 8.0 KiB [############################] /backups
4.0 KiB [############## ] docker-compose.yml
sudo btrfs filesystem usage /mnt/backupserver
Overall:
Device size: 3.64TiB
Device allocated: 3.64TiB
Device unallocated: 1.04MiB
Device missing: 0.00B
Device slack: 3.00KiB
Used: 3.55TiB
Free (estimated): 3.82MiB (min: 3.82MiB)
Free (statfs, df): 3.82MiB
Data ratio: 1.00
Metadata ratio: 2.00
Global reserve: 512.00MiB (used: 32.00KiB)
Multiple profiles: no
Data,single: Size:3.43TiB, Used:3.43TiB (100.00%)
/dev/sda1 3.43TiB
Metadata,DUP: Size:106.00GiB, Used:60.36GiB (56.94%)
/dev/sda1 212.00GiB
System,DUP: Size:32.00MiB, Used:400.00KiB (1.22%)
/dev/sda1 64.00MiB
Unallocated:
/dev/sda1 1.04MiB
Snapshots also seem to match with the backup count (101 vs. 99 / 2 Clients):
ID 262 gen 3116 top level 5 path urbackup/backups/home-services/250501-2325
ID 269 gen 11532 top level 5 path urbackup/backups/Felix-PC/250503-2227
ID 626 gen 46295 top level 5 path urbackup/backups/Felix-PC/250907-1432
ID 775 gen 53199 top level 5 path urbackup/backups/Felix-PC/251001-1218
ID 887 gen 60396 top level 5 path urbackup/backups/home-services/251020-0843
ID 924 gen 66620 top level 5 path urbackup/backups/home-services/251105-1911
ID 940 gen 81919 top level 5 path urbackup/backups/Felix-PC/251107-2320
ID 960 gen 67716 top level 5 path urbackup/backups/home-services/251112-0232
ID 961 gen 67721 top level 5 path urbackup/backups/home-services/251112-0732
ID 962 gen 79025 top level 5 path urbackup/backups/home-services/251112-1233
ID 1026 gen 80600 top level 5 path urbackup/backups/home-services/251203-1453
ID 1046 gen 81509 top level 5 path urbackup/backups/home-services/251207-1443
ID 1050 gen 81543 top level 5 path urbackup/backups/home-services/251207-1947
ID 1051 gen 81565 top level 5 path urbackup/backups/home-services/251208-0050
ID 1052 gen 81578 top level 5 path urbackup/backups/home-services/251208-0556
ID 1053 gen 81599 top level 5 path urbackup/backups/home-services/251208-1057
ID 1054 gen 81604 top level 5 path urbackup/backups/home-services/251209-0245
ID 1055 gen 81612 top level 5 path urbackup/backups/home-services/251209-0846
ID 1056 gen 81772 top level 5 path urbackup/backups/home-services/251209-1348
ID 1057 gen 92575 top level 5 path urbackup/backups/home-services/251209-1851
ID 1071 gen 83822 top level 5 path urbackup/backups/Felix-PC/251215-1137
ID 1098 gen 85902 top level 5 path urbackup/backups/Felix-PC/260101-1940
ID 1151 gen 90319 top level 5 path urbackup/backups/Felix-PC/260127-2135
ID 1170 gen 93213 top level 5 path urbackup/backups/home-services/260212-1915
ID 1209 gen 94268 top level 5 path urbackup/backups/home-services/260219-1811
ID 1251 gen 95653 top level 5 path urbackup/backups/Felix-PC/260225-1825
ID 1257 gen 95724 top level 5 path urbackup/backups/home-services/260226-1657
ID 1297 gen 96934 top level 5 path urbackup/backups/Felix-PC/260304-1923
ID 1304 gen 97185 top level 5 path urbackup/backups/home-services/260305-2008
ID 1328 gen 98853 top level 5 path urbackup/backups/Felix-PC/260309-2051
ID 1337 gen 98880 top level 5 path urbackup/backups/home-services/260312-1722
ID 1365 gen 99789 top level 5 path urbackup/backups/Felix-PC/260316-1548
ID 1367 gen 99886 top level 5 path urbackup/backups/Felix-PC/260316-2100
ID 1372 gen 99934 top level 5 path urbackup/backups/Felix-PC/260317-1320
ID 1374 gen 100042 top level 5 path urbackup/backups/Felix-PC/260317-1835
ID 1378 gen 100112 top level 5 path urbackup/backups/Felix-PC/260318-1231
ID 1382 gen 100275 top level 5 path urbackup/backups/Felix-PC/260318-2244
ID 1387 gen 100316 top level 5 path urbackup/backups/home-services/260319-2048
ID 1388 gen 100423 top level 5 path urbackup/backups/Felix-PC/260319-2108
ID 1399 gen 100896 top level 5 path urbackup/backups/Felix-PC/260321-1349
ID 1401 gen 100917 top level 5 path urbackup/backups/Felix-PC/260321-1858
ID 1403 gen 101005 top level 5 path urbackup/backups/Felix-PC/260322-0009
ID 1407 gen 101071 top level 5 path urbackup/backups/Felix-PC/260322-1556
ID 1409 gen 101195 top level 5 path urbackup/backups/Felix-PC/260322-2109
ID 1415 gen 101288 top level 5 path urbackup/backups/Felix-PC/260323-1814
ID 1417 gen 108377 top level 5 path urbackup/backups/Felix-PC/260324-0017
ID 1424 gen 110770 top level 5 path urbackup/backups/home-services/260326-1900
ID 2115 gen 111634 top level 5 path urbackup/backups/Felix-PC/260401-1502
ID 2117 gen 111740 top level 5 path urbackup/backups/Felix-PC/260401-2014
ID 2122 gen 112064 top level 5 path urbackup/backups/Felix-PC/260402-1653
ID 2123 gen 112090 top level 5 path urbackup/backups/home-services/260402-2059
ID 2147 gen 112893 top level 5 path urbackup/backups/Felix-PC/260407-1050
ID 2150 gen 112920 top level 5 path urbackup/backups/Felix-PC/260407-1601
ID 2152 gen 113061 top level 5 path urbackup/backups/Felix-PC/260407-2113
ID 2156 gen 113101 top level 5 path urbackup/backups/Felix-PC/260408-1255
ID 2158 gen 113149 top level 5 path urbackup/backups/Felix-PC/260408-1948
ID 2161 gen 113327 top level 5 path urbackup/backups/Felix-PC/260409-0439
ID 2163 gen 113350 top level 5 path urbackup/backups/Felix-PC/260409-0949
ID 2165 gen 113597 top level 5 path urbackup/backups/Felix-PC/260409-1454
ID 2167 gen 113384 top level 5 path urbackup/backups/home-services/260409-2318
ID 2187 gen 114417 top level 5 path urbackup/backups/Felix-PC/260413-1537
ID 2189 gen 114530 top level 5 path urbackup/backups/Felix-PC/260413-2049
ID 2194 gen 114588 top level 5 path urbackup/backups/Felix-PC/260414-1434
ID 2196 gen 114755 top level 5 path urbackup/backups/Felix-PC/260414-2208
ID 2206 gen 115204 top level 5 path urbackup/backups/Felix-PC/260416-1414
ID 2208 gen 115243 top level 5 path urbackup/backups/Felix-PC/260416-1929
ID 2209 gen 115257 top level 5 path urbackup/backups/home-services/260416-2051
ID 2210 gen 115396 top level 5 path urbackup/backups/Felix-PC/260417-0042
ID 2211 gen 115369 top level 5 path urbackup/backups/home-services/260417-0153
ID 2212 gen 115379 top level 5 path urbackup/backups/home-services/260417-0656
ID 2213 gen 115384 top level 5 path urbackup/backups/home-services/260417-1156
ID 2214 gen 115389 top level 5 path urbackup/backups/home-services/260417-1657
ID 2215 gen 115530 top level 5 path urbackup/backups/home-services/260417-2157
ID 2217 gen 115631 top level 5 path urbackup/backups/home-services/260418-0257
ID 2218 gen 115636 top level 5 path urbackup/backups/home-services/260418-0757
ID 2219 gen 115641 top level 5 path urbackup/backups/home-services/260418-1258
ID 2220 gen 115646 top level 5 path urbackup/backups/home-services/260418-1758
ID 2221 gen 115652 top level 5 path urbackup/backups/home-services/260418-2258
ID 2222 gen 115780 top level 5 path urbackup/backups/home-services/260419-0358
ID 2223 gen 115785 top level 5 path urbackup/backups/home-services/260419-0859
ID 2224 gen 115990 top level 5 path urbackup/backups/home-services/260419-1359
ID 2226 gen 116101 top level 5 path urbackup/backups/home-services/260419-1859
ID 2227 gen 116185 top level 5 path urbackup/backups/home-services/260420-0001
ID 2229 gen 116410 top level 5 path urbackup/backups/home-services/260420-0502
ID 2230 gen 116455 top level 5 path urbackup/backups/home-services/260420-1004
ID 2231 gen 116692 top level 5 path urbackup/backups/Felix-PC/260420-1328
ID 2232 gen 116709 top level 5 path urbackup/backups/home-services/260420-1504
ID 2233 gen 117441 top level 5 path urbackup/backups/Felix-PC/260420-1851
ID 2234 gen 116727 top level 5 path urbackup/backups/home-services/260420-2004
ID 2235 gen 116764 top level 5 path urbackup/backups/home-services/260421-0105
ID 2236 gen 117151 top level 5 path urbackup/backups/home-services/260421-0606
ID 2237 gen 117210 top level 5 path urbackup/backups/home-services/260421-1106
ID 2238 gen 117437 top level 5 path urbackup/backups/Felix-PC/260421-1447
ID 2239 gen 117428 top level 5 path urbackup/backups/home-services/260421-1607
ID 2240 gen 117450 top level 5 path urbackup/backups/home-services/260421-2110
ID 2242 gen 117485 top level 5 path urbackup/backups/home-services/260422-0214
ID 2243 gen 117490 top level 5 path urbackup/backups/home-services/260422-0715
ID 2244 gen 117495 top level 5 path urbackup/backups/home-services/260422-1216
ID 2245 gen 117500 top level 5 path urbackup/backups/home-services/260422-1716
ID 2246 gen 117506 top level 5 path urbackup/backups/home-services/260422-2217
ID 2247 gen 117510 top level 5 path urbackup/backups/home-services/260423-0317
vs.
| |Backup time|Backup ID|Incremental|Size|Archived?|Actions|
| |04/20/26 19:00|1251|Yes|3.65 GB|☑||
| |04/20/26 13:38|1249|Yes|39.33 GB|☐||
| |04/17/26 00:56|1228|Yes|2.45 GB|☐||
| |04/16/26 19:38|1226|Yes|5.45 GB|☑||
| |04/16/26 14:28|1224|Yes|44.41 GB|☐||
| |04/14/26 22:10|1214|Yes|4.67 GB|☐||
| |04/14/26 14:43|1212|Yes|6.65 GB|☐||
| |04/13/26 20:58|1207|Yes|2.74 GB|☐||
| |04/13/26 15:46|1205|Yes|37.24 GB|☐||
| |04/09/26 14:55|1183|Yes|1.48 GB|☑||
| |04/09/26 09:50|1181|Yes|1.48 GB|☐||
| |04/09/26 04:48|1179|Yes|25.75 GB|☐||
| |04/08/26 19:57|1176|Yes|2.31 GB|☐||
| |04/08/26 13:04|1174|Yes|4.29 GB|☐||
| |04/07/26 21:21|1170|Yes|1.28 GB|☐||
| |04/07/26 16:10|1167|Yes|1.87 GB|☐||
| |04/07/26 11:00|1165|Yes|36.89 GB|☐||
| |04/02/26 17:02|1140|Yes|53.2 GB|☑||
| |04/01/26 20:23|1135|Yes|5.12 GB|☐||
| |04/01/26 15:12|1133|Yes|37.21 GB|☐||
| |03/24/26 00:27|1109|Yes|8.27 GB|☑||
| |03/23/26 18:23|1107|Yes|13.01 GB|☐||
| |03/22/26 21:21|1101|Yes|21.17 GB|☐||
| |03/22/26 16:05|1099|Yes|7.96 GB|☐||
| |03/22/26 00:18|1095|Yes|15.38 GB|☐||
| |03/21/26 19:07|1093|Yes|6.9 GB|☐||
| |03/21/26 13:58|1091|Yes|25.09 GB|☐||
| |03/19/26 21:17|1080|Yes|9.44 GB|☐||
| |03/18/26 22:46|1074|Yes|9.74 GB|☑||
| |03/18/26 12:40|1070|Yes|15.67 GB|☐||
| |03/17/26 18:44|1066|Yes|2.42 GB|☐||
| |03/17/26 13:31|1063|Yes|10.4 GB|☐||
| |03/16/26 21:09|1059|Yes|2.67 GB|☐||
| |03/09/26 21:02|1020|Yes|56.28 GB|☑||
| |03/04/26 19:32|989|Yes|4.59 GB|☑||
| |02/25/26 18:34|945|Yes|825.59 MB|☑||
| |01/27/26 21:45|847|Yes|5.72 GB|☑||
| |01/01/26 19:48|796|Yes|20.93 GB|☑||
| |12/15/25 11:46|771|Yes|15.12 GB|☑||
| |11/07/25 23:32|675|Yes|1.86 GB|☑||
| |10/01/25 13:26|520|Yes|12.74 GB|☑||
| |09/07/25 14:58|372|Yes|75.19 GB|☑||
| |05/03/25 23:41|8|No|937.9 GB|☑||
| |04/23/26 03:17|1264|Yes|0 bytes|☑||
| |04/22/26 22:17|1263|Yes|0 bytes|☐||
| |04/22/26 17:16|1262|Yes|0 bytes|☐||
| |04/22/26 12:16|1261|Yes|0 bytes|☐||
| |04/22/26 07:15|1260|Yes|0 bytes|☐||
| |04/22/26 02:14|1259|Yes|0 bytes|☐||
| |04/21/26 21:10|1258|Yes|0 bytes|☐||
| |04/21/26 16:07|1257|Yes|0 bytes|☐||
| |04/21/26 11:06|1255|Yes|0 bytes|☐||
| |04/21/26 06:06|1254|Yes|0 bytes|☐||
| |04/21/26 01:05|1253|Yes|0 bytes|☐||
| |04/20/26 20:04|1252|Yes|79.13 KB|☐||
| |04/20/26 15:04|1250|Yes|0 bytes|☐||
| |04/20/26 10:04|1248|Yes|0 bytes|☐||
| |04/20/26 05:02|1247|Yes|0 bytes|☐||
| |04/20/26 00:01|1245|Yes|0 bytes|☐||
| |04/19/26 18:59|1244|Yes|0 bytes|☐||
| |04/19/26 13:59|1242|Yes|0 bytes|☐||
| |04/19/26 08:59|1241|Yes|0 bytes|☐||
| |04/19/26 03:58|1240|Yes|0 bytes|☐||
| |04/18/26 22:58|1239|Yes|0 bytes|☐||
| |04/18/26 17:58|1238|Yes|0 bytes|☐||
| |04/18/26 12:58|1237|Yes|0 bytes|☐||
| |04/18/26 07:57|1236|Yes|0 bytes|☐||
| |04/18/26 02:57|1235|Yes|0 bytes|☐||
| |04/17/26 21:57|1233|Yes|0 bytes|☐||
| |04/17/26 16:57|1232|Yes|0 bytes|☐||
| |04/17/26 11:56|1231|Yes|0 bytes|☐||
| |04/17/26 06:56|1230|Yes|0 bytes|☐||
| |04/17/26 01:53|1229|Yes|0 bytes|☐||
| |04/16/26 20:51|1227|Yes|0 bytes|☑||
| |04/09/26 23:18|1185|Yes|0 bytes|☑||
| |04/02/26 20:59|1141|Yes|0 bytes|☑||
| |03/26/26 19:00|1116|Yes|67.02 KB|☑||
| |03/19/26 20:48|1079|Yes|0 bytes|☑||
| |03/12/26 17:22|1029|Yes|0 bytes|☑||
| |03/05/26 20:08|996|Yes|0 bytes|☑||
| |02/26/26 16:57|950|Yes|0 bytes|☑||
| |02/19/26 18:11|903|Yes|33.21 KB|☑||
| |02/12/26 19:15|866|Yes|1.75 MB|☑||
| |12/09/25 18:51|761|Yes|0 bytes|☑||
| |12/09/25 13:48|760|Yes|0 bytes|☑||
| |12/09/25 08:46|759|Yes|0 bytes|☑||
| |12/09/25 02:45|758|Yes|608.61 KB|☑||
| |12/08/25 10:57|757|Yes|505.7 KB|☑||
| |12/08/25 05:56|756|Yes|0 bytes|☑||
| |12/08/25 00:53|755|Yes|668 bytes|☑||
| |12/07/25 19:47|754|Yes|7.57 MB|☑||
| |12/07/25 14:43|751|Yes|3.92 MB|☑||
| |12/03/25 14:53|732|Yes|25.98 MB|☑||
| |11/12/25 12:33|697|Yes|0 bytes|☑||
| |11/12/25 07:32|696|Yes|0 bytes|☑||
| |11/12/25 02:32|695|Yes|0 bytes|☑||
| |11/05/25 19:11|659|Yes|0 bytes|☑||
| |10/20/25 08:43|631|Yes|0 bytes|☑||
| |05/01/25 23:48|1|No|101.76 GB|☐||
Any ideas where those extra 2TB are coming from?
