I’ve installed Urbackup on my Linux laptop as a container. It works, but the backup data is stored within the container on /media/BACKUP/urbackup, which is not where I would like it. I want to store backups on an external drive (doesn’t everyone?), and am currently using a USB stick for experimental purposes - /media/jim/3F21-4AFB, mounted on the host laptop.
It seems that it’s not quite straightforward to write backups to a location on the host machine, and a search came up with this command
docker run -t -i -v /media/jim/3F21-4AFB/:/media/BACKUP/urbackup ubuntu /bin/bash
Which appears to link the container location to the host location.
I tentatively tried it, but nothing gets written to the USB stick.
I’d be grateful for a bit of handholding, please!
Jim
Hmm - it looks like maybe urbackup isn’t for me!
I was attracted to it because installation and the Web UI configuration looked quite straightforward - and it was up to a point, but as soon as you need to depart a fraction from the defaults you’re up to your neck in obscure docker features and cryptic commands that make SED commands and APL code look as clear as spring water!
Jim
Ultimately I may end up installing it without docker, but I see the advantage of docker and will try to get my head around it. But new concepts don’t come easily at my age!
Jim
