I am SSHed into the appliance now. There is no log by that name, below is a listing of that path:
alternatives.log btmp daemon.log.1 faillog messages syslog.3.gz wtmp
apt chrony debug install_packages.list messages.1 syslog.4.gz
auth.log cloud-init.log debug.1 kern.log syslog unattended-upgrades
auth.log.1 cloud-init-output.log dpkg.log kern.log.1 syslog.1 user.log
bootstrap.log daemon.log fai lastlog syslog.2.gz user.log.1
Below is the cloud-init.log
2020-10-20 14:56:10,734 - helpers.py[DEBUG]: config-timezone already ran (freq=once-per-instance)
2020-10-20 14:56:10,734 - handlers.py[DEBUG]: finish: modules-config/config-timezone: SUCCESS: config-timezone previously ran
2020-10-20 14:56:10,734 - stages.py[DEBUG]: Running module disable-ec2-metadata (<module ‘cloudinit.config.cc_disable_ec2_metadata’ from ‘/usr/lib/python3/dist-packages/cloudinit/config/cc_disable_ec2_metadata.py’>) with frequency always
2020-10-20 14:56:10,735 - handlers.py[DEBUG]: start: modules-config/config-disable-ec2-metadata: running config-disable-ec2-metadata with frequency always
2020-10-20 14:56:10,735 - helpers.py[DEBUG]: Running config-disable-ec2-metadata using lock (<cloudinit.helpers.DummyLock object at 0x7fbbb909ecc0>)
2020-10-20 14:56:10,735 - cc_disable_ec2_metadata.py[DEBUG]: Skipping module named disable-ec2-metadata, disabling the ec2 route not enabled
2020-10-20 14:56:10,735 - handlers.py[DEBUG]: finish: modules-config/config-disable-ec2-metadata: SUCCESS: config-disable-ec2-metadata ran successfully
2020-10-20 14:56:10,735 - stages.py[DEBUG]: Running module runcmd (<module ‘cloudinit.config.cc_runcmd’ from ‘/usr/lib/python3/dist-packages/cloudinit/config/cc_runcmd.py’>) with frequency once-per-instance
2020-10-20 14:56:10,735 - handlers.py[DEBUG]: start: modules-config/config-runcmd: running config-runcmd with frequency once-per-instance
2020-10-20 14:56:10,735 - helpers.py[DEBUG]: config-runcmd already ran (freq=once-per-instance)
2020-10-20 14:56:10,735 - handlers.py[DEBUG]: finish: modules-config/config-runcmd: SUCCESS: config-runcmd previously ran
2020-10-20 14:56:10,735 - stages.py[DEBUG]: Running module byobu (<module ‘cloudinit.config.cc_byobu’ from ‘/usr/lib/python3/dist-packages/cloudinit/config/cc_byobu.py’>) with frequency once-per-instance
2020-10-20 14:56:10,735 - handlers.py[DEBUG]: start: modules-config/config-byobu: running config-byobu with frequency once-per-instance
2020-10-20 14:56:10,735 - helpers.py[DEBUG]: config-byobu already ran (freq=once-per-instance)
2020-10-20 14:56:10,735 - handlers.py[DEBUG]: finish: modules-config/config-byobu: SUCCESS: config-byobu previously ran
2020-10-20 14:56:10,735 - main.py[DEBUG]: Ran 12 modules with 0 failures
2020-10-20 14:56:10,736 - util.py[DEBUG]: Reading from /proc/uptime (quiet=False)
2020-10-20 14:56:10,736 - util.py[DEBUG]: Read 10 bytes from /proc/uptime
2020-10-20 14:56:10,736 - util.py[DEBUG]: cloud-init mode ‘modules’ took 0.064 seconds (0.06)
2020-10-20 14:56:10,736 - handlers.py[DEBUG]: finish: modules-config: SUCCESS: running modules for config
2020-10-20 14:56:11,233 - util.py[DEBUG]: Cloud-init v. 0.7.9 running ‘modules:final’ at Tue, 20 Oct 2020 14:56:11 +0000. Up 7.78 seconds.
2020-10-20 14:56:11,267 - stages.py[DEBUG]: Using distro class <class ‘cloudinit.distros.debian.Distro’>
2020-10-20 14:56:11,268 - stages.py[DEBUG]: Running module package-update-upgrade-install (<module ‘cloudinit.config.cc_package_update_upgrade_install’ from ‘/usr/lib/python3/dist-packages/cloudinit/config/cc_package_update_upgrade_install.py’>) with frequency once-per-instance
2020-10-20 14:56:11,268 - handlers.py[DEBUG]: start: modules-final/config-package-update-upgrade-install: running config-package-update-upgrade-install with frequency once-per-instance
2020-10-20 14:56:11,268 - helpers.py[DEBUG]: config-package-update-upgrade-install already ran (freq=once-per-instance)
2020-10-20 14:56:11,269 - handlers.py[DEBUG]: finish: modules-final/config-package-update-upgrade-install: SUCCESS: config-package-update-upgrade-install previously ran
2020-10-20 14:56:11,269 - stages.py[DEBUG]: Running module fan (<module ‘cloudinit.config.cc_fan’ from ‘/usr/lib/python3/dist-packages/cloudinit/config/cc_fan.py’>) with frequency once-per-instance
2020-10-20 14:56:11,269 - handlers.py[DEBUG]: start: modules-final/config-fan: running config-fan with frequency once-per-instance
2020-10-20 14:56:11,269 - helpers.py[DEBUG]: config-fan already ran (freq=once-per-instance)
2020-10-20 14:56:11,269 - handlers.py[DEBUG]: finish: modules-final/config-fan: SUCCESS: config-fan previously ran
2020-10-20 14:56:11,269 - stages.py[DEBUG]: Running module puppet (<module ‘cloudinit.config.cc_puppet’ from ‘/usr/lib/python3/dist-packages/cloudinit/config/cc_puppet.py’>) with frequency once-per-instance
2020-10-20 14:56:11,269 - handlers.py[DEBUG]: start: modules-final/config-puppet: running config-puppet with frequency once-per-instance
2020-10-20 14:56:11,269 - helpers.py[DEBUG]: config-puppet already ran (freq=once-per-instance)
2020-10-20 14:56:11,269 - handlers.py[DEBUG]: finish: modules-final/config-puppet: SUCCESS: config-puppet previously ran
2020-10-20 14:56:11,269 - stages.py[DEBUG]: Running module chef (<module ‘cloudinit.config.cc_chef’ from ‘/usr/lib/python3/dist-packages/cloudinit/config/cc_chef.py’>) with frequency once-per-instance
2020-10-20 14:56:11,269 - handlers.py[DEBUG]: start: modules-final/config-chef: running config-chef with frequency once-per-instance
2020-10-20 14:56:11,269 - helpers.py[DEBUG]: config-chef already ran (freq=once-per-instance)
2020-10-20 14:56:11,270 - handlers.py[DEBUG]: finish: modules-final/config-chef: SUCCESS: config-chef previously ran
2020-10-20 14:56:11,270 - stages.py[DEBUG]: Running module salt-minion (<module ‘cloudinit.config.cc_salt_minion’ from ‘/usr/lib/python3/dist-packages/cloudinit/config/cc_salt_minion.py’>) with frequency once-per-instance
2020-10-20 14:56:11,270 - handlers.py[DEBUG]: start: modules-final/config-salt-minion: running config-salt-minion with frequency once-per-instance
2020-10-20 14:56:11,270 - helpers.py[DEBUG]: config-salt-minion already ran (freq=once-per-instance)
2020-10-20 14:56:11,270 - handlers.py[DEBUG]: finish: modules-final/config-salt-minion: SUCCESS: config-salt-minion previously ran
2020-10-20 14:56:11,270 - stages.py[DEBUG]: Running module mcollective (<module ‘cloudinit.config.cc_mcollective’ from ‘/usr/lib/python3/dist-packages/cloudinit/config/cc_mcollective.py’>) with frequency once-per-instance
2020-10-20 14:56:11,270 - handlers.py[DEBUG]: start: modules-final/config-mcollective: running config-mcollective with frequency once-per-instance
2020-10-20 14:56:11,270 - helpers.py[DEBUG]: config-mcollective already ran (freq=once-per-instance)
2020-10-20 14:56:11,270 - handlers.py[DEBUG]: finish: modules-final/config-mcollective: SUCCESS: config-mcollective previously ran
2020-10-20 14:56:11,270 - stages.py[DEBUG]: Running module rightscale_userdata (<module ‘cloudinit.config.cc_rightscale_userdata’ from ‘/usr/lib/python3/dist-packages/cloudinit/config/cc_rightscale_userdata.py’>) with frequency once-per-instance
2020-10-20 14:56:11,271 - handlers.py[DEBUG]: start: modules-final/config-rightscale_userdata: running config-rightscale_userdata with frequency once-per-instance
2020-10-20 14:56:11,271 - helpers.py[DEBUG]: config-rightscale_userdata already ran (freq=once-per-instance)
2020-10-20 14:56:11,271 - handlers.py[DEBUG]: finish: modules-final/config-rightscale_userdata: SUCCESS: config-rightscale_userdata previously ran
2020-10-20 14:56:11,271 - stages.py[DEBUG]: Running module scripts-vendor (<module ‘cloudinit.config.cc_scripts_vendor’ from ‘/usr/lib/python3/dist-packages/cloudinit/config/cc_scripts_vendor.py’>) with frequency once-per-instance
2020-10-20 14:56:11,271 - handlers.py[DEBUG]: start: modules-final/config-scripts-vendor: running config-scripts-vendor with frequency once-per-instance
2020-10-20 14:56:11,271 - helpers.py[DEBUG]: config-scripts-vendor already ran (freq=once-per-instance)
2020-10-20 14:56:11,271 - handlers.py[DEBUG]: finish: modules-final/config-scripts-vendor: SUCCESS: config-scripts-vendor previously ran
2020-10-20 14:56:11,271 - stages.py[DEBUG]: Running module scripts-per-once (<module ‘cloudinit.config.cc_scripts_per_once’ from ‘/usr/lib/python3/dist-packages/cloudinit/config/cc_scripts_per_once.py’>) with frequency once
2020-10-20 14:56:11,271 - handlers.py[DEBUG]: start: modules-final/config-scripts-per-once: running config-scripts-per-once with frequency once
2020-10-20 14:56:11,271 - helpers.py[DEBUG]: config-scripts-per-once already ran (freq=once)
2020-10-20 14:56:11,272 - handlers.py[DEBUG]: finish: modules-final/config-scripts-per-once: SUCCESS: config-scripts-per-once previously ran
2020-10-20 14:56:11,272 - stages.py[DEBUG]: Running module scripts-per-boot (<module ‘cloudinit.config.cc_scripts_per_boot’ from ‘/usr/lib/python3/dist-packages/cloudinit/config/cc_scripts_per_boot.py’>) with frequency always
2020-10-20 14:56:11,272 - handlers.py[DEBUG]: start: modules-final/config-scripts-per-boot: running config-scripts-per-boot with frequency always
2020-10-20 14:56:11,272 - helpers.py[DEBUG]: Running config-scripts-per-boot using lock (<cloudinit.helpers.DummyLock object at 0x7fdc0d918e48>)
2020-10-20 14:56:11,273 - handlers.py[DEBUG]: finish: modules-final/config-scripts-per-boot: SUCCESS: config-scripts-per-boot ran successfully
2020-10-20 14:56:11,273 - stages.py[DEBUG]: Running module scripts-per-instance (<module ‘cloudinit.config.cc_scripts_per_instance’ from ‘/usr/lib/python3/dist-packages/cloudinit/config/cc_scripts_per_instance.py’>) with frequency once-per-instance
2020-10-20 14:56:11,273 - handlers.py[DEBUG]: start: modules-final/config-scripts-per-instance: running config-scripts-per-instance with frequency once-per-instance
2020-10-20 14:56:11,274 - helpers.py[DEBUG]: config-scripts-per-instance already ran (freq=once-per-instance)
2020-10-20 14:56:11,274 - handlers.py[DEBUG]: finish: modules-final/config-scripts-per-instance: SUCCESS: config-scripts-per-instance previously ran
2020-10-20 14:56:11,274 - stages.py[DEBUG]: Running module scripts-user (<module ‘cloudinit.config.cc_scripts_user’ from ‘/usr/lib/python3/dist-packages/cloudinit/config/cc_scripts_user.py’>) with frequency once-per-instance
2020-10-20 14:56:11,274 - handlers.py[DEBUG]: start: modules-final/config-scripts-user: running config-scripts-user with frequency once-per-instance
2020-10-20 14:56:11,274 - helpers.py[DEBUG]: config-scripts-user already ran (freq=once-per-instance)
2020-10-20 14:56:11,274 - handlers.py[DEBUG]: finish: modules-final/config-scripts-user: SUCCESS: config-scripts-user previously ran
2020-10-20 14:56:11,274 - stages.py[DEBUG]: Running module ssh-authkey-fingerprints (<module ‘cloudinit.config.cc_ssh_authkey_fingerprints’ from ‘/usr/lib/python3/dist-packages/cloudinit/config/cc_ssh_authkey_fingerprints.py’>) with frequency once-per-instance
2020-10-20 14:56:11,274 - handlers.py[DEBUG]: start: modules-final/config-ssh-authkey-fingerprints: running config-ssh-authkey-fingerprints with frequency once-per-instance
2020-10-20 14:56:11,274 - helpers.py[DEBUG]: config-ssh-authkey-fingerprints already ran (freq=once-per-instance)
2020-10-20 14:56:11,274 - handlers.py[DEBUG]: finish: modules-final/config-ssh-authkey-fingerprints: SUCCESS: config-ssh-authkey-fingerprints previously ran
2020-10-20 14:56:11,274 - stages.py[DEBUG]: Running module keys-to-console (<module ‘cloudinit.config.cc_keys_to_console’ from ‘/usr/lib/python3/dist-packages/cloudinit/config/cc_keys_to_console.py’>) with frequency once-per-instance
2020-10-20 14:56:11,274 - handlers.py[DEBUG]: start: modules-final/config-keys-to-console: running config-keys-to-console with frequency once-per-instance
2020-10-20 14:56:11,275 - helpers.py[DEBUG]: config-keys-to-console already ran (freq=once-per-instance)
2020-10-20 14:56:11,275 - handlers.py[DEBUG]: finish: modules-final/config-keys-to-console: SUCCESS: config-keys-to-console previously ran
2020-10-20 14:56:11,275 - stages.py[DEBUG]: Running module phone-home (<module ‘cloudinit.config.cc_phone_home’ from ‘/usr/lib/python3/dist-packages/cloudinit/config/cc_phone_home.py’>) with frequency once-per-instance
2020-10-20 14:56:11,275 - handlers.py[DEBUG]: start: modules-final/config-phone-home: running config-phone-home with frequency once-per-instance
2020-10-20 14:56:11,275 - helpers.py[DEBUG]: config-phone-home already ran (freq=once-per-instance)
2020-10-20 14:56:11,275 - handlers.py[DEBUG]: finish: modules-final/config-phone-home: SUCCESS: config-phone-home previously ran
2020-10-20 14:56:11,275 - stages.py[DEBUG]: Running module final-message (<module ‘cloudinit.config.cc_final_message’ from ‘/usr/lib/python3/dist-packages/cloudinit/config/cc_final_message.py’>) with frequency always
2020-10-20 14:56:11,275 - handlers.py[DEBUG]: start: modules-final/config-final-message: running config-final-message with frequency always
2020-10-20 14:56:11,275 - helpers.py[DEBUG]: Running config-final-message using lock (<cloudinit.helpers.DummyLock object at 0x7fdc0d86a9b0>)
2020-10-20 14:56:11,276 - util.py[DEBUG]: Reading from /proc/uptime (quiet=False)
2020-10-20 14:56:11,276 - util.py[DEBUG]: Read 10 bytes from /proc/uptime
2020-10-20 14:56:11,284 - util.py[DEBUG]: Cloud-init v. 0.7.9 finished at Tue, 20 Oct 2020 14:56:11 +0000. Datasource DataSourceEc2. Up 7.89 seconds
2020-10-20 14:56:11,284 - util.py[DEBUG]: Writing to /var/lib/cloud/instance/boot-finished - wb: [420] 50 bytes
2020-10-20 14:56:11,285 - handlers.py[DEBUG]: finish: modules-final/config-final-message: SUCCESS: config-final-message ran successfully
2020-10-20 14:56:11,285 - stages.py[DEBUG]: Running module power-state-change (<module ‘cloudinit.config.cc_power_state_change’ from ‘/usr/lib/python3/dist-packages/cloudinit/config/cc_power_state_change.py’>) with frequency once-per-instance
2020-10-20 14:56:11,286 - handlers.py[DEBUG]: start: modules-final/config-power-state-change: running config-power-state-change with frequency once-per-instance
2020-10-20 14:56:11,286 - helpers.py[DEBUG]: config-power-state-change already ran (freq=once-per-instance)
2020-10-20 14:56:11,286 - handlers.py[DEBUG]: finish: modules-final/config-power-state-change: SUCCESS: config-power-state-change previously ran
2020-10-20 14:56:11,286 - main.py[DEBUG]: Ran 17 modules with 0 failures
2020-10-20 14:56:11,287 - util.py[DEBUG]: Creating symbolic link from ‘/run/cloud-init/result.json’ => ‘…/…/var/lib/cloud/data/result.json’
2020-10-20 14:56:11,287 - util.py[DEBUG]: Reading from /proc/uptime (quiet=False)
2020-10-20 14:56:11,287 - util.py[DEBUG]: Read 10 bytes from /proc/uptime
2020-10-20 14:56:11,287 - util.py[DEBUG]: cloud-init mode ‘modules’ took 0.127 seconds (0.13)
2020-10-20 14:56:11,287 - handlers.py[DEBUG]: finish: modules-final: SUCCESS: running modules for final
