I have recently purchased licenses for my Windows clients. I downloaded the server_update_location.url file (and verified it is named correctly) and placed it in my /var/urbackup folder though I am not seeing any of the clients get updated. I am running the server in a docker container and have the following persistent volume bind /home/user/urbackup/db:/var/urbackup–so, I know the .url file persists container restarts. I have gone into the container and verified it can see and read the .url file. Is there a way I can check to see if the server is actually downloading the CBT client and is there any other setting in the WebUI other than General → Server → Autoupdate clients Enabled to check?
I have restarted the container several times and all Windows clients have rebooted at least twice now–none are showing “Show CBT status” in the About section of the tray icon.
Should I just wait for a newer release or should I manually change the Window’s clients? Is there a recommended process for this and which of the binaries should I use: UrBackup Client 2.5.31-cbt(x64).msi, UrBackupUpdate.exe, UrBackup Client 2.5.31-cbt.exe?
