I’m in a major bind trying to figure out how to restore an an image backup. I’m running urbackup in a docker on my unraid server, which backups a Windows 11 client on my network. In the process of trying to fix various issues, I think I’ve corrupted my urbackup database (even though I tried restoring it from the backup it saves). As a result (I think), when I try to use the bootable recovery usb, even though it lists my backups, when I try to start a restore I get messages “Loading MBR failed: Error reading image size from server” and “MBR info not found. Cannot restore to partition”.
That said, I still have all my backup vhdz files. As an alternative I was trying to assemble a .vhd to try restoring with another program. However when I run the following command (from shell within the docker)
urbackupsrv assemble -a /media/5600x-Dsktp/250217-0203_Image_SYSVOL/Image_SYSVOL_250217-0203.vhdz -a /media/5600x-Dsktp/250217-0204_Image_C/Image_C_250217-0204.vhdz -a /media/5600x-Dsktp/250217-0204_Image_ESP/Image_ESP_250217-0204.vhdz -o /media/VHD/250127.vhd
I get the following output:
2025-03-02 14:21:08: Clustersize: 4096
2025-03-02 14:21:08: ClustersPerMFTNode Offset: 48
2025-03-02 14:21:08: MFTStart: 72448
2025-03-02 14:21:08: Attribute Type: 16 nonresident=0 length=96
2025-03-02 14:21:08: Filename=$MFT
2025-03-02 14:21:08: Attribute Type: 48 nonresident=0 length=104
2025-03-02 14:21:08: Attribute Type: 128 nonresident=1 length=72
2025-03-02 14:21:08: Filename=$Bitmap
2025-03-02 14:21:08: Bitmap size=27168
2025-03-02 14:21:08: VHD-Parent: "/media/5600x-Dsktp/250120-0251_Image_C/Image_C_250120-0251.vhdz"
2025-03-02 14:21:08: Sectorsize: 512
2025-03-02 14:21:08: MFTStart: 125278833
2025-03-02 14:21:08: Attribute Type: 128 nonresident=1 length=96
2025-03-02 14:21:08: Bitmap size=31195616
2025-03-02 14:21:08: ERROR: NTFS magic wrong
2025-03-02 14:21:08: WARNING: Volume not an NTFS volume. Copying all blocks...
2025-03-02 14:21:08: ERROR: Footer checksum wrong. Switching to header
2025-03-02 14:21:09: Writing GPT header...
Segmentation fault
This happens no matter which image I try to assemble (I’ve tried several older ones). I’m not totally sure if I’m supposed to be including the ESP vhdz in the assemble, but even assembling just the C drive also produces a seg fault.
I do think that the image itself is okay, as I am able to mount it using urbackupsrv mount-vhd (after running my docker in privileged mode) and browse the files from the docker shell.
I’ve seen a couple other posts with similar issues assembling NTFS vhdz files, but they have no responses.
I’m pretty desperate here. If assembling a VHDZ isn’t going to work, is there anything else I can try to get this image restored to my drive? I had been nervous about using the cleanup or remove-unknown commands for fear they will wipe my actual image backups, though I am in the process of backing up the images and then going to try that. I have already tried running repair-database and defrag-database but they both result in various errors (happy to reply with those if needed).
Any suggestions towards the ultimate goal of restoring a image to my Windows 11 machine are much appreciated!
