Here is a brief summary of my setup :
- client : manjaro 5.4.89-1-MANJARO, client version 2.4.11
server : debian 8 (jessie) – can’t upgrade this one
server version UrBackup Server 2.0.38 Rev. 85153c7771
It used to work properly for ages but since a recent kernel upgrade on the client nothing works anymore.
The client can’t be updated by AUR anymore. Every version requires to uninstall wxgtk which I need.
I followed the advices here and modified the “depends” to wxgtk2 and I could manually install the package…
The backend crashes everytime. I tried to look at the logs and here is what I have when I start the client with
-v debug
On the client :
logs
2021-01-28 18:31:04: ERROR: Signature error: No challenge
2021-01-28 18:31:04: rc=0 hasError=true state=0
2021-01-28 18:33:11: Internet mode not enabled
2021-01-28 18:37:04: ClientService cmd: #ItoghIxxxxxx___skipped___xxxxi#GET CHALLENGE
2021-01-28 18:37:04: rc=0 hasError=true state=0
2021-01-28 18:37:04: ClientService cmd: #ItoghIxxx___skipped___
cli
% sudo urbackupclientbackend -v debug
[sudo] password for quentin:
2021-01-28 18:47:32: SQLite: recovered 9648 frames from WAL file /var/urbackup/backup_client.db-wal code: 283
2021-01-28 18:47:32: urbackupserver: Server started up successfully!
2021-01-28 18:47:32: FileSrv: Binding UDP socket at port 35622...
2021-01-28 18:47:32: FileSrv: done.
2021-01-28 18:47:32: FileSrv: Binding ipv6 UDP socket at port 35622...
2021-01-28 18:47:32: FileSrv: Servername: -qkzk-
2021-01-28 18:47:32: Started UrBackupClient Backend...
2021-01-28 18:47:32: FileSrv: Server started up successfully
2021-01-28 18:47:32: FileSrv: UDP Thread started
2021-01-28 18:47:33: Looking for old Sessions... 0 sessions
2021-01-28 18:47:33: Internet mode not enabled
2021-01-28 18:47:33: Final path: /home
2021-01-28 18:47:33: Final path: /etc
2021-01-28 18:47:33: Final path: /usr/share/zoneinfo/Europe/Paris
2021-01-28 18:47:33: Final path: /usr/lib/os-release
2021-01-28 18:47:33: Final path: /usr/bin/python3.9
2021-01-28 18:48:18: urbackupserver: No available slots... starting new Worker
2021-01-28 18:48:18: ClientService cmd: #ItoghIeBLhMxwJhkqRMyi#ADD IDENTITY
2021-01-28 18:48:18: rc=0 hasError=true state=0
2021-01-28 18:48:18: ClientService cmd: #ItoghIeBLhMxwJhkqRMyi#GET CHALLENGE
2021-01-28 18:48:18: ClientService cmd: #ItoghIeBLhMxwJhkqRMyi#SIGNATURE#pubkey=MIIBtzC___skipped___
[1] 750213 segmentation fault sudo urbackupclientbackend -v debug
On the server :
2021-01-28 03:28:13: ERROR: Error while downloading version info from http://update3.urbackup.org/version_osx.txt: HTTP response code said error(ec=22), The requested URL returned error: 404 Not Found
2021-01-28 17:36:52: ERROR: Connecting to ClientService of "qkzk" failed: Error sending server signature to client
2021-01-28 17:44:23: ERROR: Connecting to ClientService of "qkzk" failed: Error sending server signature to client
2021-01-28 18:12:40: WARNING: Shutting down (Signal 15)
2021-01-28 18:13:42: ERROR: Error while downloading version info from http://update3.urbackup.org/version_osx.txt: HTTP response code said error(ec=22), The requested URL returned error: 404 Not Found
2021-01-28 18:15:43: ERROR: Connecting to ClientService of "qkzk" failed: Error sending server signature to client
2021-01-28 18:31:04: ERROR: Error sending server signature to client
2021-01-28 18:38:44: ERROR: Connecting to ClientService of "qkzk" failed: Error sending server signature to client
2021-01-28 18:49:58: ERROR: Connecting to ClientService of "qkzk" failed: Error sending server signature to client
- When I try the GUI it doesn’t work either (I guess the
depends
fix wasn’t such a good idea afterall)
I can click on a few elements but every time I get an error message…
What should I do ?
- Reinstall the client, trying to force a wxgtk-something ?
- Reset the configuration ? Where ? Directly from the server ?
- Wait for a fix ?
Well, a few years after my first installation, once again I’m stuck !
Thanks in advance for your answers and, obviously, for the wonderfull software
