I need to use Archive option to keep files which are removed at a backup source.
My configuration is:
but it is not working - Archive flag do not appear next to backup.
Please let me know what i am doing wrong ?!
And another question - what is “File backup” and what is the difference between it and “Incremental/Full file backup” ?
If you select “File backup” it archives any file backup, otherwise only a incremental or full.
Can you check if you go to the client specific setting of NWHR2S, that the archival settings are correctly present? If “separate settings for this client” is checked the global archival settings do not correctly propagate to the clients in some cases (just found this error).
Yes that is true - after i choose “File backup” now my full backup start archiving - but if i choose “Full file backup” no matter what my Full file backup do not start to be archiving - i suppose it is bug ?!
Sorry. Lost track of this issue. It’s probably the same as Bug in archive file type handling
