Alerts section, two questions about email notifications
  • email came notifying me that no backups for 15 hours on some machine, where did the 15 hours number came from and how can I adjust it?
  • there is something called alert_nag_interval in the alerts section what is it? I set it to 30 minutes, and it was not sending me email every 30 minutes that no backup has been done for 30 min.
The settings alert tab has two entries “Number of times the file backup interval after which the file backup status is set to not ok” and “Number of times the image backup interval after which the image backup status is set to not ok”. I assume the 15 hours is the product of the applicable multiplier and the interval you use.
You could adjust the multiplier or the interval.
yeap, tested it when I set the file backup interval to 1 hour and number of fails before not-ok to 1
thnx
