It would be really great if we could add tags to clients, as computer names usually don’t carry the name of the user, but instead an internal number, for example PC-298304. Every time that I receive a warning, I have to look at a separate list and compare, because while I do know most of the users, I don’t know the internal number of their PC.
You can use any name for the client.
It’s a setting in the per/client section.
Be aware that it does not change immediately. There appears to be some background housekeeping that changes it !
Yeah, but that’s the “PC NAME”. Wouldn’t it mismatch the client, if the names aren’t matching anymore? Also, I have 40+ clients, so every time that I want to submit a change globally, I would have to manually update all 40 clients.
