I’m still working on my NethServer module, I have now something workable to install urbackup on a Centos6 but I would love to change some settings directly after the installation without human interactions.
I mean to give the backup folder (/var/lib/urbackup for example) without the need to set it manually in the setting page and also create the admin and set a password.
For this I attempted to open and modify the database backup_server_settings.db, but I have an error message back.
[root@nethserver-dev urbackup]# sqlite3 /var/urbackup/backup_server_settings.db
SQLite version 3.6.20
Enter ".help" for instructions
Enter SQL statements terminated with a ";"
sqlite> .tables
Error: file is encrypted or is not a database
sqlite> .quit
if I try another sqlite database it is the same problem
[root@nethserver-dev urbackup]# sqlite3 backup_server_settings.db
sqlite> .tables
I use centos6.7
[root@nethserver-dev urbackup]# cat /etc/redhat-release
CentOS release 6.7 (Final)
and urbackup 1.4.14
[root@nethserver-dev urbackup]# rpm -qa |grep urbackup
urbackup-server-1.4.14-3.1.x86_64
nethserver-urbackup-0.0.2-1.ns6.sdl.noarch
I’m not sure it is normal
do you have another idea ??
