K1LLA
January 8, 2024, 4:14am
1
My network controllers are:
Intel(R) Ethernet Controller I226-V
Intel(R) Wi-Fi 6E AX211 160MHz
MOBO: MSI MAG Z790 Tomohawk wifi (MS-7D91)
I am unable to connect to my network with the restore USB 2.4.2 (x64)
Can I add drivers to the USB files? If so how would I do that?
The restore system is Linux, so may complicate things alittle.
K1LLA
January 10, 2024, 2:53am
3
Well that’s fine. I am restoring from a Linux based Server (Unraid), but cant reach that server simply because it cannot find the network. Can I restore from a direct-attached storage?
uroni
January 10, 2024, 7:01pm
4
It got a little bit easier.
Fork GitHub - uroni/urbackup_restore_cd: Builds the UrBackup Restore ISO which allows full system image restores , modify it then run the github action which directly creates the iso.
You might also see a newer image there. Maybe that one has a driver, though I am not sure if it works completely yet (not finished testing).
