Hi Uroni,
i often get file backups stating 0 Bytes, for example:
1217 BA-TPM-JM Volles Datei Backup 13.03.2013 13:35 32 min 0 bytes
Bit it backuped about 5gigabytes of data and I also can restore it. Will you fix that in near future?
Hi Uroni,
It should update at some point. It does not update while other backups are in progress.
I’ll try to not show it unless it is calculated completely. Issue: https://urbackup.atlassian.net/browse/US-3
