Wrong SYSVOL volume backed up
Backuping a laptop with a recovery partition seems to result with the recovery partition backed up instead of the SYSVOL partition :
Mounting partition :
Regards,
Could you post the “C:\Program Files\UrBackup\sysvol_test.exe” output. That shows how it searches for the SYSVOL.
C:\Users\thomas>"C:\Program Files\UrBackup\sysvol_test.exe" Filesystem. Vol="\\?\Volume{3b31e943-4acc-11e7-b8ae-806e6f6e6963}\" Name="recove ry" Type="ntfs" VPaths=0 Size=13151236096 Bootable flag set for volume Found potential candidate: \\?\Volume{3b31e943-4acc-11e7-b8ae-806e6f6e6963}\ Sco re: 3 Filesystem. Vol="\\?\Volume{3b31e944-4acc-11e7-b8ae-806e6f6e6963}\" Name="os" Ty pe="ntfs" VPaths=1 Size=242865926144 Filesystem is System partition. Skipping... Filesystem. Vol="\\?\Volume{01108dde-4b58-11e7-8002-ecf4bb4945b9}\" Name="" Type ="" VPaths=1 Size=-1 GetVolumeInformation failed with error code 21. Skipping... Selected volume \\?\Volume{3b31e943-4acc-11e7-b8ae-806e6f6e6963} Found sysvol "\\?\Volume{3b31e943-4acc-11e7-b8ae-806e6f6e6963}" Path: "" Trying to open SYSVOL(\\?\Volume{3b31e943-4acc-11e7-b8ae-806e6f6e6963})... Successfully opened SYSVOL. System dir: C:\Windows Volpath: \\.\C: Device is not GPT formatted (0) Found no EFI System Partition No EFI System Partition found. Trying to open EFI System Partition()... Could not open EFI System Partition(). Last error=3
Could you run it as administrator? Thanks!
That’s what i’ve done :
Ok, it doesn’t even list this volume, does it?
A little bit of research shows this is a HP/Dell partition for bootable diagnostics and has nothing to do with Windows. Correct?
Yes, correct. This is a manufacturer recovery partition (DELL) containing the “stock” win 7 image.
Here is the DISKPART output :
DISKPART> select disk 0
Le disque 0 est maintenant le disque sélectionné.
DISKPART> list partition
N° partition Type Taille Décalage
Partition 1 OEM 39 M 31 K
Partition 2 Principale 12 G 40 M
Partition 3 Principale 226 G 12 G
DISKPART>
Partition 1 = SYSVOL ???
Partition 2 = DELL RECOVERY
Partition 3 = OS (C:)
I’d say Partition 2 is SYSVOL and Partition 1 is ??? (bootable diagnostics but nothing to do with Windows). Partition 2 has the Boot and recovery directories my SYSVOL has. Plus SYSVOL is formatted NTFS and OEM is FAT32, isn’t it?
Oh yes sorry that’s it … Partition 1 is a Dell partition for bootable diagnostics. Partition 2 named RECOVERY contains some wim files (DELL stock images for recovering to initial state). And partition 3 is C:
And partition 2 also contains the “System Volume Information” directory, sorry for the mistake …
