I’ve had UrBackup running for about 3 weeks with no problems. This morning, after restarting my server, I find that browsers no longer connects to the server UI. http://localhost:55414/ just hangs in Firefox and IE. I’m looking for ideas to troubleshoot. I’ve got the firewall down. Everything else seems to work (web server, etc). If all else fails, can I reinstall without loosing my data? I’ve got 4 internet-connected clients out there.
Thanx. Give me a few minutes to make it readable - no line breaks
Gobs of errors. Here are the last few. What should I be looking for?
2015-08-05 06:43:41: ERROR: Error opening file ‘E:\urbackup\phil-hp\Image_SYSVOL_150630-1548.vhdz’
2015-08-05 09:58:52: ERROR: Querying client capabilities failed
2015-08-05 09:58:52: ERROR: Timeout: Querying client capabilities failed
2015-08-05 09:59:06: WARNING: Cannot retrieve last file backup when doing incremental backup. Doing full backup now…
2015-08-05 10:03:19: ERROR: Connecting to ClientService of “Tracy” failed: Sending version to client failed
2015-08-05 10:13:19: ERROR: Error opening file ‘E:\urbackup\phil-hp\Image_SYSVOL_150630-1548.vhdz’
2015-08-05 11:33:11: WARNING: Cannot retrieve last file backup when doing incremental backup. Doing full backup now…
2015-08-05 11:40:02: WARNING: Restarting shadow copy of C:\ because it was started by this server
2015-08-05 11:42:35: ERROR: Error opening file ‘E:\urbackup\phil-hp\Image_SYSVOL_150630-1548.vhdz’
2015-08-05 14:39:08: ERROR: Error opening file ‘E:\urbackup\phil-hp\Image_SYSVOL_150630-1548.vhdz’
On the way. Thank you!
Can’t see anything that directly indicates your problem.
2015-08-05 06:42:22: WARNING: Sending mail failed. Couldn't resolve host name(ec=6), Could not resolve host: mail.xxxx; No data record of requested type
2015-08-05 06:42:22: ERROR: Error opening file 'E:\urbackup\xxx\Image_SYSVOL_150630-1548.vhdz'
2015-08-05 06:42:38: ERROR: Error while downloading version info from http://update2.urbackup.org/version.txt: Couldn't resolve host name(ec=6), Could not resolve host: update2.urbackup.org; No data record of requested type
Something may be wrong with your networking? (DNS)
Also maybe run C:\Program Files\UrBackupServer\defrag_database.bat
to check if the database is working.
Not sure about networking - reset a router this morning - about when the problem showed up.
Started the bat file and got
Stopping the Urbackup Server
The UrBackup Windows server service is stopping
The UrBackup Windows server service was stopped successfully
And the a dialog box: This application has failed to start because ktmw32.dll was not found…
Ok, it is not using urbackupserver_prevista.dll in this script. Never mind. Those operating systems aren’t supported by Microsoft anyways.
I restarted the service. Guess what! I’m getting a web UI both locally and remotely.
Well. that didn’t last long. This morning, I notices some clients disconnected. I restarted the server again. The clients seem to have come back but my web interface is gone again.
