Are there any plans to fix VSS on TrueCrypt / VeraCrypt?
Currently it fails, which results in inconsistent backups…
UrBackup just uses the Windows API. It needs to be implemented on the VeraCrypt side.
I have no issues backing up TC/VC volumes with UrBackup on Win 7 or Win 8.1.
If you’re using Win XP. Lie and set the TC/VC setting that says the volume is removable.
