Local backup no encryption but compression was on.
Hey Uroni! Thanks for making an awesome product!
I’ve been having some trouble getting incremental image backups working on 2.x. I had no troubles with the 1.4.x, but nothing I do with 2.x seems to work. Here are the details:
Server: 2.0.7 on Debian 8.3 (.deb install), fresh install, not upgraded
Client: 2.0.6 on Windows 7 VM for testing (fully updated, VMware Tools installed), no other software installed
Symptoms (reproducible):
- Full/Incremental file backups - [OK]
- First full image backup - [OK]
- Next full or image backup - [client debug.log: Pipe to client unexpectedly closed has_error=true]
Things I’ve tried:
- 1.4.11 client on Windows 7 VM [no improvement]
Let me know if there’s anything else I can try.
Cheers,
G
Client debug.log: more details:
2016-03-27 13:12:58: ClientService cmd: #IpHMaOv0EdEIcsuwMfK4C#2LOGDATA 1459109576 0-1459108493-Starting incremental image backup…
0-1459108496-Basing image backup on last incremental or full image backup
1-1459108496-Error retrieving last image backup. Doing full image backup instead.
0-1459109576-Transferred 7.38894 GB - Average speed: 58.7678 MBit/s
0-1459109576-(Before compression: 16.5801 GB ratio: 2.24391)
0-1459109576-Time taken for backing up client URTest1: 18m 3s
0-1459109576-Backup succeeded
2016-03-27 13:12:58: rc=0 hasError=true state=0
2016-03-27 13:12:58: SERVICE_COMMANDS finished
2016-03-27 13:12:58: ClientService cmd: STATUS DETAIL#pw=0uooFOGy1uKJfxqLvSRp6Kg8ubIlm2
2016-03-27 13:12:58: Number of Writers: 10
2016-03-27 13:12:58: Writer Task Scheduler Writer has failure state VSS_WS_STABLE with error S_OK.
2016-03-27 13:12:58: Writer VSS Metadata Store Writer has failure state VSS_WS_STABLE with error S_OK.
2016-03-27 13:12:58: Writer Performance Counters Writer has failure state VSS_WS_STABLE with error S_OK.
2016-03-27 13:12:58: Writer System Writer has failure state VSS_WS_STABLE with error S_OK.
2016-03-27 13:12:58: Writer ASR Writer has failure state VSS_WS_STABLE with error S_OK.
2016-03-27 13:12:58: Writer COM+ REGDB Writer has failure state VSS_WS_STABLE with error S_OK.
2016-03-27 13:12:58: Writer MSSearch Service Writer has failure state VSS_WS_STABLE with error S_OK.
2016-03-27 13:12:58: Writer Shadow Copy Optimization Writer has failure state VSS_WS_STABLE with error S_OK.
2016-03-27 13:12:58: Writer Registry Writer has failure state VSS_WS_STABLE with error S_OK.
2016-03-27 13:12:58: Writer WMI Writer has failure state VSS_WS_STABLE with error S_OK.
2016-03-27 13:12:58: ClientService cmd: STATUS#pw=0uooFOGy1uKJfxqLvSRp6Kg8ubIlm2
2016-03-27 13:12:59: Deleting Shadowcopy for dir “C:”
2016-03-27 13:12:59: Service finished. Transferred 7.38894 GB
2016-03-27 13:12:59: Encryption overhead: 1.2066 MB
2016-03-27 13:12:59: Transferred uncompressed: 16.5813 GB (ratio: 2.24443)
2016-03-27 13:12:59: Average sent paket size: 32.28 MB
2016-03-27 13:12:59: SERVICE_COMMANDS finished
2016-03-27 13:13:07: rc=0 hasError=true state=0
2016-03-27 13:13:07: SERVICE_COMMANDS finished
2016-03-27 13:13:07: ClientService cmd: STATUS DETAIL#pw=0uooFOGy1uKJfxqLvSRp6Kg8ubIlm2
2016-03-27 13:13:08: Started connection to SERVICE_COMMANDS
2016-03-27 13:13:08: ClientService cmd: #IpHMaOv0EdEIcsuwMfK4C#FULL IMAGE letter=SYSVOL&token=yxgqdYXHak6mkfz9IhQK&bitmap=1&status_id=7
2016-03-27 13:13:08: Filesystem type is ntfs (\?\Volume{a4573615-f23a-11e5-99ce-806e6f6e6963})
2016-03-27 13:13:08: TotalNumberOfClusters=25599 numberOfClusters=25599 n_clusters=3200 StartingLcn=0 BitmapSize=25599 r_bytes=3216
2016-03-27 13:13:08: FSINFO: blocksize=4096 size=104857088 has_error=false used_space=25337856
2016-03-27 13:13:08: ClientService cmd: #IpHMaOv0EdEIcsuwMfK4C#2PING RUNNING pc_done=0&status_id=7&speed_bpms=0&total_bytes=-1&done_bytes=0#token=yxgqdYXHak6mkfz9IhQK
2016-03-27 13:13:08: ClientService cmd: #IpHMaOv0EdEIcsuwMfK4C#MBR driveletter=SYSVOL
2016-03-27 13:13:08: rc=0 hasError=true state=0
2016-03-27 13:13:08: SERVICE_COMMANDS finished
2016-03-27 13:13:08: ClientService cmd: STATUS DETAIL#pw=0uooFOGy1uKJfxqLvSRp6Kg8ubIlm2
2016-03-27 13:13:09: Sending full image done
2016-03-27 13:13:09: Service finished. Transferred 8.11576 MB
2016-03-27 13:13:09: Encryption overhead: 1.62305 KB
2016-03-27 13:13:09: Transferred uncompressed: 24.2146 MB (ratio: 2.98423)
2016-03-27 13:13:09: Average sent paket size: 3.45921 MB
2016-03-27 13:13:09: SERVICE_COMMANDS finished
2016-03-27 13:13:09: ClientService cmd: STATUS DETAIL#pw=0uooFOGy1uKJfxqLvSRp6Kg8ubIlm2
2016-03-27 13:13:10: ClientService cmd: STATUS#pw=0uooFOGy1uKJfxqLvSRp6Kg8ubIlm2
2016-03-27 13:13:10: Started connection to SERVICE_COMMANDS
2016-03-27 13:13:10: ClientService cmd: #IpHMaOv0EdEIcsuwMfK4C#FULL IMAGE letter=ESP&token=yxgqdYXHak6mkfz9IhQK&bitmap=1&status_id=8
2016-03-27 13:13:10: ERROR: Not found
2016-03-27 13:13:10: ClientService cmd: #IpHMaOv0EdEIcsuwMfK4C#2PING RUNNING pc_done=0&status_id=8&speed_bpms=0&total_bytes=-1&done_bytes=0#token=yxgqdYXHak6mkfz9IhQK
2016-03-27 13:13:10: ClientService cmd: #IpHMaOv0EdEIcsuwMfK4C#MBR driveletter=ESP
2016-03-27 13:13:10: rc=0 hasError=true state=0
2016-03-27 13:13:10: SERVICE_COMMANDS finished
2016-03-27 13:13:10: ClientService cmd: STATUS DETAIL#pw=0uooFOGy1uKJfxqLvSRp6Kg8ubIlm2
2016-03-27 13:13:11: Started connection to SERVICE_COMMANDS
2016-03-27 13:13:11: ClientService cmd: #IpHMaOv0EdEIcsuwMfK4C#INCR IMAGE letter=C:&hashsize=4187808&token=yxgqdYXHak6mkfz9IhQK&bitmap=1&status_id=6
2016-03-27 13:13:11: Creating shadowcopy of “C:”…
2016-03-27 13:13:11: Preparing change block tracking reset for volume C: failed: Incorrect function.
(code: 1)
2016-03-27 13:13:11: Error decompressing stream(2): -3
2016-03-27 13:13:11: Error decompressing stream(1): -3
2016-03-27 13:13:11: rc=0 hasError=true state=5
2016-03-27 13:13:11: ClientService cmd: #IpHMaOv0EdEIcsuwMfK4C#MBR driveletter=C
2016-03-27 13:13:11: rc=0 hasError=true state=0
2016-03-27 13:13:11: SERVICE_COMMANDS finished
2016-03-27 13:13:11: ClientService cmd: #IpHMaOv0EdEIcsuwMfK4C#2PING RUNNING pc_done=0&status_id=6&speed_bpms=0&total_bytes=-1&done_bytes=0#token=yxgqdYXHak6mkfz9IhQK
2016-03-27 13:13:11: ClientService cmd: STATUS DETAIL#pw=0uooFOGy1uKJfxqLvSRp6Kg8ubIlm2
2016-03-27 13:13:11: Number of Writers: 10
2016-03-27 13:13:11: Writer Task Scheduler Writer has failure state VSS_WS_STABLE with error S_OK.
2016-03-27 13:13:11: Writer VSS Metadata Store Writer has failure state VSS_WS_STABLE with error S_OK.
2016-03-27 13:13:11: Writer Performance Counters Writer has failure state VSS_WS_STABLE with error S_OK.
2016-03-27 13:13:11: Writer System Writer has failure state VSS_WS_STABLE with error S_OK.
2016-03-27 13:13:11: Writer ASR Writer has failure state VSS_WS_STABLE with error S_OK.
2016-03-27 13:13:11: Writer Registry Writer has failure state VSS_WS_STABLE with error S_OK.
2016-03-27 13:13:11: Writer MSSearch Service Writer has failure state VSS_WS_STABLE with error S_OK.
2016-03-27 13:13:11: Writer COM+ REGDB Writer has failure state VSS_WS_STABLE with error S_OK.
2016-03-27 13:13:11: Writer Shadow Copy Optimization Writer has failure state VSS_WS_STABLE with error S_OK.
2016-03-27 13:13:11: Writer WMI Writer has failure state VSS_WS_STABLE with error S_OK.
2016-03-27 13:13:12: ERROR: Error receiving hashdata. timouts=3599 isquitting=true
2016-03-27 13:13:12: SERVICE_COMMANDS finished
2016-03-27 13:13:12: Number of Writers: 10
2016-03-27 13:13:12: Writer Task Scheduler Writer has failure state VSS_WS_STABLE with error S_OK.
2016-03-27 13:13:12: Writer VSS Metadata Store Writer has failure state VSS_WS_STABLE with error S_OK.
2016-03-27 13:13:12: Writer Performance Counters Writer has failure state VSS_WS_STABLE with error S_OK.
2016-03-27 13:13:12: Writer System Writer has failure state VSS_WS_STABLE with error S_OK.
2016-03-27 13:13:12: Writer ASR Writer has failure state VSS_WS_STABLE with error S_OK.
2016-03-27 13:13:12: Writer Registry Writer has failure state VSS_WS_STABLE with error S_OK.
2016-03-27 13:13:12: Writer MSSearch Service Writer has failure state VSS_WS_STABLE with error S_OK.
2016-03-27 13:13:12: Writer COM+ REGDB Writer has failure state VSS_WS_STABLE with error S_OK.
2016-03-27 13:13:12: Writer Shadow Copy Optimization Writer has failure state VSS_WS_STABLE with error S_OK.
2016-03-27 13:13:12: Writer WMI Writer has failure state VSS_WS_STABLE with error S_OK.
2016-03-27 13:13:12: ClientService cmd: STATUS DETAIL#pw=0uooFOGy1uKJfxqLvSRp6Kg8ubIlm2
2016-03-27 13:13:13: ClientService cmd: STATUS#pw=0uooFOGy1uKJfxqLvSRp6Kg8ubIlm2
2016-03-27 13:13:13: Started connection to SERVICE_COMMANDS
2016-03-27 13:13:13: ClientService cmd: #IpHMaOv0EdEIcsuwMfK4C#2LOGDATA 1459109591 0-1459109587-Starting full image backup…
0-1459109590-Basing image backup on last incremental or full image backup
0-1459109590-Creating writable snapshot of previous image backup…
2-1459109591-Pipe to client unexpectedly closed has_error=true
0-1459109591-Transferred 1.14886 MB - Average speed: 10.1875 MBit/s
0-1459109591-Time taken for backing up client URTest1: 4s
2-1459109591-Backup failed
Greg try Opening a command windows on the Windows 7 VM and type “VSSADMIN List Writers” this will give you the status of the vss snapshot services on the window 7 \vm. Also try restarting the urbackup clinet service.
Hey crashuk, thanks for the quick response!
VSSADMIN List Writers: [No errors - see below]
Restart “UrBackup Client Service for Backups” service & do full image backup: log on server:
Starting full image backup...
Creating writable snapshot of previous image backup...
Transferred 1.14886 MB - Average speed: 10.2091 MBit/s
Backup failed
VSS Details on Windows 7 VM:
vssadmin 1.1 - Volume Shadow Copy Service administrative command-line tool
© Copyright 2001-2005 Microsoft Corp.
Writer name: ‘Task Scheduler Writer’
Writer Id: {d61d61c8-d73a-4eee-8cdd-f6f9786b7124}
Writer Instance Id: {1bddd48e-5052-49db-9b07-b96f96727e6b}
State: [1] Stable
Last error: No error
Writer name: ‘VSS Metadata Store Writer’
Writer Id: {75dfb225-e2e4-4d39-9ac9-ffaff65ddf06}
Writer Instance Id: {088e7a7d-09a8-4cc6-a609-ad90e75ddc93}
State: [1] Stable
Writer name: ‘Performance Counters Writer’
Writer Id: {0bada1de-01a9-4625-8278-69e735f39dd2}
Writer Instance Id: {f0086dda-9efc-47c5-8eb6-a944c3d09381}
State: [1] Stable
Writer name: ‘System Writer’
Writer Id: {e8132975-6f93-4464-a53e-1050253ae220}
Writer Instance Id: {a34a2aef-c249-4139-8d61-81c1a11a417a}
State: [1] Stable
Writer name: ‘COM+ REGDB Writer’
Writer Id: {542da469-d3e1-473c-9f4f-7847f01fc64f}
Writer Instance Id: {43fb3059-11b4-40ac-b807-a49aa346ef44}
State: [1] Stable
Writer name: ‘ASR Writer’
Writer Id: {be000cbe-11fe-4426-9c58-531aa6355fc4}
Writer Instance Id: {3ae2374d-42a4-4761-a3b6-07557ec175a4}
State: [1] Stable
Writer name: ‘WMI Writer’
Writer Id: {a6ad56c2-b509-4e6c-bb19-49d8f43532f0}
Writer Instance Id: {2b2eec1e-659d-436b-9ea9-552846b4ae99}
State: [1] Stable
Writer name: ‘MSSearch Service Writer’
Writer Id: {cd3f2362-8bef-46c7-9181-d62844cdc0b2}
Writer Instance Id: {ec328783-1f7b-4694-9068-1150121542a0}
State: [1] Stable
Writer name: ‘Shadow Copy Optimization Writer’
Writer Id: {4dc3bdd4-ab48-4d07-adb0-3bee2926fd7f}
Writer Instance Id: {995bb839-adf4-47d7-b8d3-6cfc067f078a}
State: [1] Stable
Writer name: ‘Registry Writer’
Writer Id: {afbab4a2-367d-4d15-a586-71dbb18f8485}
Writer Instance Id: {bd4eda9c-563d-4304-85a2-792a83babae8}
State: [1] Stable
Thanks for the detailed report!
Could you upload/send me the hash file of the full image backup it is basing the incremental backup on?
Would be e.g. Image_C_160327-2201.raw.hash.
Switched from 2.0.7 deb package to 2.0.7 self compiled version with full fresh install.
server crash on first full backup
Last debug log lines follow.
2016-03-28 15:02:14: New fileindex entry for "/mnt/backup/urbackup/srv.enterprize.dyndns.info/160328-1443/root/usr/local/urbackup/var/urbackup/backup_server_files.db-wal" id=432277
2016-03-28 15:02:15: HT: Copying file: "/mnt/backup/urbackup/srv.enterprize.dyndns.info/160328-1443/root/usr/local/urbackup/var/urbackup/backup_server_link_journal.db-shm"
2016-03-28 15:02:15: New fileindex entry for "/mnt/backup/urbackup/srv.enterprize.dyndns.info/160328-1443/root/usr/local/urbackup/var/urbackup/backup_server_link_journal.db-shm" id=432278
2016-03-28 15:02:15: HT: Copying file: "/mnt/backup/urbackup/srv.enterprize.dyndns.info/160328-1443/root/usr/local/urbackup/var/urbackup/backup_server_link_journal.db-wal"
2016-03-28 15:02:15: New fileindex entry for "/mnt/backup/urbackup/srv.enterprize.dyndns.info/160328-1443/root/usr/local/urbackup/var/urbackup/backup_server_link_journal.db-wal" id=432279
2016-03-28 15:02:15: HT: Copying file: "/mnt/backup/urbackup/srv.enterprize.dyndns.info/160328-1443/root/usr/local/urbackup/var/urbackup/backup_server_links.db-shm"
2016-03-28 15:02:15: New fileindex entry for "/mnt/backup/urbackup/srv.enterprize.dyndns.info/160328-1443/root/usr/local/urbackup/var/urbackup/backup_server_links.db-shm" id=432280
2016-03-28 15:02:15: HT: Copying file: "/mnt/backup/urbackup/srv.enterprize.dyndns.info/160328-1443/root/usr/local/urbackup/var/urbackup/backup_server_links.db-wal"
2016-03-28 15:02:15: New fileindex entry for "/mnt/backup/urbackup/srv.enterprize.dyndns.info/160328-1443/root/usr/local/urbackup/var/urbackup/backup_server_links.db-wal" id=432281
2016-03-28 15:02:15: HT: Copying file: "/mnt/backup/urbackup/srv.enterprize.dyndns.info/160328-1443/root/usr/local/urbackup/var/urbackup/backup_server_settings.db-shm"
2016-03-28 15:02:15: New fileindex entry for "/mnt/backup/urbackup/srv.enterprize.dyndns.info/160328-1443/root/usr/local/urbackup/var/urbackup/backup_server_settings.db-shm" id=432282
2016-03-28 15:02:15: HT: Copying file: "/mnt/backup/urbackup/srv.enterprize.dyndns.info/160328-1443/root/usr/local/urbackup/var/urbackup/backup_server_settings.db-wal"
2016-03-28 15:02:15: New fileindex entry for "/mnt/backup/urbackup/srv.enterprize.dyndns.info/160328-1443/root/usr/local/urbackup/var/urbackup/backup_server_settings.db-wal" id=432283
2016-03-28 15:02:15: HT: Copying file: "/mnt/backup/urbackup/srv.enterprize.dyndns.info/160328-1443/root/usr/local/urbackup/var/urbackup/fileindex/backup_server_files_index.lmdb"
2016-03-28 15:02:15: New fileindex entry for "/mnt/backup/urbackup/srv.enterprize.dyndns.info/160328-1443/root/usr/local/urbackup/var/urbackup/fileindex/backup_server_files_index.lmdb" id=432284
2016-03-28 15:02:15: HT: Copying file: "/mnt/backup/urbackup/srv.enterprize.dyndns.info/160328-1443/root/usr/local/urbackup/var/urbackup/fileindex/backup_server_files_index.lmdb-lock"
2016-03-28 15:02:15: ERROR: dstfsize=4096 tfilesize=8192
urbackupsrv: urbackupserver/server_hash.cpp:1436: bool BackupServerHash::patchFile(IFile*, const string&, const string&, std::string, std::string, _i64, ExtentIterator*): Assertion `dstfsize==tfilesize' failed.
Abgebrochen
No Client errors…
Is this is with a client without snapshots?
Confirmed no snapshots running on the client VM.
Ok, will do some tests with file sizes changing during backups. Thanks! (Not that it makes much sense backing up files like this
Since upgrading to the latest beta I have not been able to complete any backups. My office desktop that backs up over the LAN is failing with errors such as:
Errors
03/28/16 10:35
GetVolumePathName(dir.target, volume_path, MAX_PATH) failed
Errors
03/28/16 10:35
Creating snapshot of “E” failed.
Errors
03/28/16 10:35
Cannot access path to backup: "E:" Errorcode: 3 - The system cannot find the path specified.
Errors
03/28/16 10:35
Constructing of filelist of “Office-Desktop” failed: error - index error
Errors
03/28/16 10:35
Backup had an early error. Deleting partial backup.
An external client that backs up over the internet is failing with errors such as:
Errors
03/28/16 12:40
Error getting complete file “uNpbmmwlG0NiStiiFlay|F/Data/30 - *redacted (MAMA)/PR Materials/Logo (2015)/redacted/EPS/redacted 4Color CMYK.eps” from redacted-Server. Errorcode: FILE_DOESNT_EXIST (3)
Errors
03/28/16 12:40
Client redacted-Server went offline.
Errors
03/28/16 12:47
Backup failed
If you need full logs or anything, just let me know what you want and I will dump them in the Google Drive share that I have sent you before.
If you meant my error uroni…
Running Datto
Snapshot is available and beeing used…
New issue - backup now taking 1 hour when it should take 2-3 minutes
Backup started but stops at 100% for hour then completes.
This a local backup on the network.
Log below
Log: (Home-PC)
Level Time Message
Info
03/29/16 11:56
Starting incremental file backup…
Info
03/29/16 11:57
Scanning for changed hard links on volume of “Desktop”…
Info
03/29/16 11:57
Indexing of “Desktop” done. 1 filesystem lookups 2 db lookups and 0 db updates
Info
03/29/16 11:57
Scanning for changed hard links on volume of “Stuff”…
Info
03/29/16 11:57
Indexing of “Stuff” done. 1 filesystem lookups 907 db lookups and 0 db updates
Info
03/29/16 11:57
Indexing of “Documents” done. 1 filesystem lookups 68 db lookups and 0 db updates
Info
03/29/16 11:57
Indexing of “BitShare” done. 1 filesystem lookups 3320 db lookups and 0 db updates
Info
03/29/16 11:57
Home-PC: Loading file list…
Info
03/29/16 11:57
Home-PC: Calculating file tree differences…
Info
03/29/16 11:57
Home-PC: Calculating tree difference size…
Info
03/29/16 11:57
Home-PC: Linking unchanged and loading new files…
Info
03/29/16 11:57
Waiting for file transfers…
Info
03/29/16 12:57
Waiting for file hashing and copying threads…
Info
03/29/16 12:57
Saving file metadata…
Info
03/29/16 12:57
Writing new file list…
Info
03/29/16 12:57
All metadata was present
Info
03/29/16 12:57
Transferred 1.18507 MB - Average speed: 2.752 KBit/s
Info
03/29/16 12:57
Time taken for backing up client Home-PC: 1h 31s
Info
03/29/16 12:57
Backup succeeded
This log is from when I was running v2.0.5 server
Level Time Message
Info
03/23/16 20:24
Info
03/23/16 20:24
Info
03/23/16 20:24
Info
03/23/16 20:24
Info
03/23/16 20:24
Info
03/23/16 20:24
Indexing of “Documents” done. 1 filesystem lookups 27 db lookups and 0 db updates
Info
03/23/16 20:24
Info
03/23/16 20:24
Info
03/23/16 20:25
Info
03/23/16 20:25
Info
03/23/16 20:25
Info
03/23/16 20:25
Info
03/23/16 20:25
Info
03/23/16 20:25
Info
03/23/16 20:25
Info
03/23/16 20:25
Info
03/23/16 20:25
Transferred 1.18331 MB - Average speed: 1.80774 MBit/s
Info
03/23/16 20:25
Time taken for backing up client Home-PC: 30s
Info
03/23/16 20:25
Backup succeeded
@tarakesh Sorry got confused. Must be something else then.
@crashuk
Could you have a look at the debug log to see what it is doing in the extra hour? Perhaps the live log will also show some extra info during the backup.
@john3354 The first one looks like the backup up is missing? The second one could be an error I’ve been trying to track. I’ll try to reproduce that and if I can’t come back to your offer. Thanks!
I told the server to do a full file backup. We will see if that helps. No idea why it would say the backup is missing? That error only started after I upgraded to the latest beta.
As for the second, if there is anyway that I can help just let me know. I will get you whatever information that you need.
I have installed 2.0.6 client on my Windows 10 laptop, installed with default settings.
Now I get this error in mail:
ERROR: Client calculated hash of “/media/backup/urbackup//BornData - Søren Yoga 13/160330-0951/C/swapfile.sys” differs from server calculated hash. This may be caused by a bug or by random bit flips on the client or server hard disk. Failing backup.
ERROR: FATAL: Backup failed because of disk problems
The page file should automatically be excluded. Could you have a look if it is listed in the registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management\ExistingPagefiles ?
Edit: Ok, it is a new pagefile for Windows 10 Universal apps… Now I have to find a registry key for that one…
Hey Uroni,
Did you receive the hash file I sent via email?
Can anyone else confirm if they have successfully completed incremental image backups using copy-on-write/btrfs snapshots? I’m also backing up over the internet if that makes any difference.
Yes, thanks! Should be fixed with the version I just released.
Testing EFI/GPT restores
Urbackup 2.0.8 Server, Debian 8 with btrfs formatted storage ( no compression ). Intel Core 2 Quad with 4GB RAM.
Urbackup 2.0.6 Client, Windows 10 Pro.
Installed Windows 10 on an Intel NUC, with EFI enabled in the BIOS. Created a full image of the NUC.
Restored the NUC image onto a VirtualBox VM with EFI support enabled. Chose install onto dissimilar hardware option. Worked perfectly.
Restored the NUC image onto an AMD based M/B. Chose install onto dissimilar hardware option. On first boot Windows diagnosed the install then after a restart booted to the desktop. I then scanned for new drivers in device manager and Windows 10 downloaded drivers off the Internet. Worked perfectly.
Determined to break UrBackup, I did the same with another, different chipset, AMD based M/B. Same result. Worked perfectly.
The restore speed was around 6 minutes for the 15 GB image on my gigabit network and I’m not using SSD drives.
Combined with the ability to do synthetic incremental images with btrfs, simply awesome.
