The Image backup does not backup correctly any drives that are using the GPT partition.
It simply will not backup the sysvol partition or EFI, which causes issues with an incomplete image that can then not be used. I am on a windows 10 host, trying to use the images as a backup VHD to boot up in VirtualBox, as some of our servers still run on GPT and cannot be converted.
EDIT:
After doing a clean install of windows (again GPT) UrBackup is now taking images of the correct volumes, however the UrBackup server batch file for merging the images gives me “ERROR: Trying to write beyond partition”
