I have urbackup working with a CIFS mounted, as you know CIFS doesnt support symlinks so I desactivated this option on settings.
Im only using file transfers on clients, making an incremental 5 times in a day.
The problem is… the creation of LOTS of folders from the same client and they are not automaticly being deleted.
for example this is a client folder on server of backed up:
drwxrwxrwx. 0 root root 0 Jan 8 14:59 160106-1550
drwxrwxrwx. 0 root root 0 Jan 6 16:55 160106-1552
drwxrwxrwx. 0 root root 0 Jan 8 14:59 160107-1658
drwxrwxrwx. 0 root root 0 Jan 7 23:05 160107-2202
drwxrwxrwx. 0 root root 0 Jan 8 04:06 160108-0303
drwxrwxrwx. 0 root root 0 Jan 8 09:07 160108-0804
drwxrwxrwx. 0 root root 0 Jan 8 14:08 160108-1305
drwxrwxrwx. 0 root root 0 Jan 8 19:09 160108-1805
drwxrwxrwx. 0 root root 0 Jan 9 00:10 160108-2306
drwxrwxrwx. 0 root root 0 Jan 9 05:11 160109-0407
drwxrwxrwx. 0 root root 0 Jan 9 10:12 160109-0909
drwxrwxrwx. 0 root root 0 Jan 9 15:13 160109-1409
drwxrwxrwx. 0 root root 0 Jan 9 20:14 160109-1910
drwxrwxrwx. 0 root root 0 Jan 10 01:15 160110-0011
drwxrwxrwx. 0 root root 0 Jan 10 06:16 160110-0512
drwxrwxrwx. 0 root root 0 Jan 10 11:17 160110-1013
drwxrwxrwx. 0 root root 0 Jan 10 16:18 160110-1514
drwxrwxrwx. 0 root root 0 Jan 10 21:19 160110-2015
drwxrwxrwx. 0 root root 0 Jan 11 02:20 160111-0116
drwxrwxrwx. 0 root root 0 Jan 11 07:21 160111-0617
drwxrwxrwx. 0 root root 0 Jan 11 12:22 160111-1118
drwxrwxrwx. 0 root root 0 Jan 11 13:49 160111-1245
drwxrwxrwx. 0 root root 0 Jan 11 18:51 160111-1747
drwxrwxrwx. 0 root root 0 Jan 11 23:52 160111-2248
drwxrwxrwx. 0 root root 0 Jan 12 04:53 160112-0349
drwxrwxrwx. 0 root root 0 Jan 12 09:54 160112-0850
drwxrwxrwx. 0 root root 0 Jan 12 14:55 160112-1351
drwxrwxrwx. 0 root root 0 Jan 12 19:56 160112-1852
drwxrwxrwx. 0 root root 0 Jan 13 00:58 160112-2353
drwxrwxrwx. 0 root root 0 Jan 13 05:59 160113-0455
drwxrwxrwx. 0 root root 0 Jan 13 11:00 160113-0956
drwxrwxrwx. 0 root root 0 Jan 13 16:02 160113-1457
drwxrwxrwx. 0 root root 0 Jan 13 21:03 160113-1959
drwxrwxrwx. 0 root root 0 Jan 14 02:05 160114-0100
drwxrwxrwx. 0 root root 0 Jan 14 07:07 160114-0602
drwxrwxrwx. 0 root root 0 Jan 14 12:08 160114-1103
drwxrwxrwx. 0 root root 0 Jan 14 17:09 160114-1605
drwxrwxrwx. 0 root root 0 Jan 14 22:10 160114-2106
drwxrwxrwx. 0 root root 0 Jan 15 03:13 160115-0207
drwxrwxrwx. 0 root root 0 Jan 15 08:14 160115-0710
drwxrwxrwx. 0 root root 0 Jan 15 13:16 160115-1211
drwxrwxrwx. 0 root root 0 Jan 15 18:18 160115-1712
drwxrwxrwx. 0 root root 0 Jan 15 23:20 160115-2215
drwxrwxrwx. 0 root root 0 Jan 16 04:31 160116-0317
drwxrwxrwx. 0 root root 0 Jan 16 09:34 160116-0828
drwxrwxrwx. 0 root root 0 Jan 16 14:38 160116-1331
drwxrwxrwx. 0 root root 0 Jan 16 19:41 160116-1834
drwxrwxrwx. 0 root root 0 Jan 17 00:45 160116-2338
drwxrwxrwx. 0 root root 0 Jan 17 05:49 160117-0442
drwxrwxrwx. 0 root root 0 Jan 17 10:52 160117-0945
drwxrwxrwx. 0 root root 0 Jan 17 15:57 160117-1449
drwxrwxrwx. 0 root root 0 Jan 17 21:00 160117-1953
drwxrwxrwx. 0 root root 0 Jan 18 02:06 160118-0057
drwxrwxrwx. 0 root root 0 Jan 18 07:13 160118-0602
drwxrwxrwx. 0 root root 0 Jan 18 12:50 160118-1145
drwxrwxrwx. 0 root root 0 Jan 18 17:51 160118-1646
drwxrwxrwx. 0 root root 0 Jan 18 22:52 160118-2147
drwxrwxrwx. 0 root root 0 Jan 19 03:53 160119-0248
drwxrwxrwx. 0 root root 0 Jan 19 08:54 160119-0750
drwxrwxrwx. 0 root root 0 Jan 19 13:55 160119-1251
drwxrwxrwx. 0 root root 0 Jan 19 18:56 160119-1752
drwxrwxrwx. 0 root root 0 Jan 19 23:57 160119-2252
drwxrwxrwx. 0 root root 0 Jan 20 04:58 160120-0353
drwxrwxrwx. 0 root root 0 Jan 20 09:59 160120-0855
drwxrwxrwx. 0 root root 0 Jan 20 15:00 160120-1355
drwxrwxrwx. 0 root root 0 Jan 20 20:01 160120-1856
drwxrwxrwx. 0 root root 0 Jan 21 01:02 160120-2357
drwxrwxrwx. 0 root root 0 Jan 21 06:03 160121-0458
drwxrwxrwx. 0 root root 0 Jan 21 11:04 160121-0959
drwxrwxrwx. 0 root root 0 Jan 21 16:05 160121-1500
drwxrwxrwx. 0 root root 0 Jan 21 21:06 160121-2001
drwxrwxrwx. 0 root root 0 Jan 22 02:07 160122-0102
drwxrwxrwx. 0 root root 0 Jan 22 07:09 160122-0603
As you can see, those are folders created in every incremental execution and all of them are using the same space.
I just want keep 2 last incremental folders.
In settings this is my configuration.
Maximal number of incremental file backups: 2
Minimal number of incremental file backups: 2
Maximal number of full file backups: 2
Minimal number of full file backups: 2
Thanks you in advance.
