Hi guys. I have run a small urbackup server for about 2 years to do a file backup of two PCs (total backup server size is about 3 TB). I have run the remove-unknown function once a month to clean up the database/files and have never had a problem with it (it generally takes 2 days to complete). A number of months ago there was a urbackup update and the remove-unknown function no longer completes. At present, it has been running for 3 months! It’s doing something; it’s always got a substantial amount of either CPU or IO utilization. The log shows only the following types of messages:
2018-07-09 06:54:51: WARNING: Adding missing directory reference of pool nRbtDavlMd1497462779147202437 to “/var/urbackup_files/THUNDERSTORM/170612-1927/.hashes/C/Windows/Globalization/ELS”
2018-07-09 06:55:03: WARNING: Adding missing directory reference of pool nRbtDavlMd1497462779147202437 to “/var/urbackup_files/THUNDERSTORM/170613-0031/.hashes/C/Windows/Globalization/ELS”
2018-07-09 06:55:10: WARNING: Adding missing directory reference of pool nRbtDavlMd1497462779147202437 to “/var/urbackup_files/THUNDERSTORM/170613-0958/.hashes/C/Windows/Globalization/ELS”
2018-07-09 06:55:17: WARNING: Adding missing directory reference of pool nRbtDavlMd1497462779147202437 to “/var/urbackup_files/THUNDERSTORM/170613-1505/.hashes/C/Windows/Globalization/ELS”
2018-07-09 06:55:24: WARNING: Adding missing directory reference of pool nRbtDavlMd1497462779147202437 to “/var/urbackup_files/THUNDERSTORM/170613-2230/.hashes/C/Windows/Globalization/ELS”
2018-07-09 06:55:33: WARNING: Adding missing directory reference of pool nRbtDavlMd1497462779147202437 to “/var/urbackup_files/THUNDERSTORM/170614-0332/.hashes/C/Windows/Globalization/ELS”
Should I just delete all the file backups and start over? Any help in resolving this problem would be appreciated!
Thanks,
James
