Hi. I decided to delete the client. Put a checkmark and hit the remove selected. After the client began to move away, can’t go into activities. Backup status says “This client is going to be removed. Stop removing client. Clients are removed during the cleanup time window, if they are offline.” How to fix?
at first - the same stuff was asked before - so please check the old threads before asking the same questions and please next time add more infos to your post like e.g. server version and used os.
We and others had the same issues - take a look viewtopic.php?f=1&t=197
We fixed the problem with our Windows server in the following order - hope it helps:
- Stop your server and check the size of your UrBackup DB and if necessary fix it like uroni suggested in viewtopic.php?f=1&t=191#p1031
- Install the newest RC Server Version from http://sourceforge.net/projects/urbackup/files/Server/ and your good to go.
Since 1.2RC we have no longer performance or deletion issues with the server.
With best regards …
hupsing
