I have NanoPi NEO 2 with NAS Kit like this.
- CPU: Allwinner H5, Quad-core 64-bit high-performance Cortex A53
- DDR3 RAM: 512MB
Remote client installed on VPS Linux, 4 Gb Ram, 1 CPU core.
I’ve successfully made full files backup.
After this I tried to made incremental files backup. After I click on Incremental file backup web interface stop answering.
service urbackupsrv status
● urbackupsrv.service - LSB: Server for doing backups
Loaded: loaded (/etc/init.d/urbackupsrv; bad; vendor preset: enabled)
Active: active (exited) since Fri 2019-09-27 14:47:51 CEST; 16min ago
Docs: man:systemd-sysv-generator(8)
Process: 12424 ExecStop=/etc/init.d/urbackupsrv stop (code=exited, status=0/SU
Process: 12433 ExecStart=/etc/init.d/urbackupsrv start (code=exited, status=0/
Tasks: 0
Memory: 0B
CPU: 0
Then I restarted server and checked status
Active: active (running) since Fri 2019-09-27 15:06:04 CEST; 6s ago
Process: 13560 ExecStop=/etc/init.d/urbackupsrv stop (code=exited, status=0/SU
Process: 13569 ExecStart=/etc/init.d/urbackupsrv start (code=exited, status=0/
Tasks: 3
Memory: 55.1M
CPU: 1.573s
CGroup: /system.slice/urbackupsrv.service
└─13576 /usr/bin/urbackupsrv run --config /etc/default/urbackupsrv
Also I found this message after server restarted
UrBackup is upgrading its internal database. This may take a while. The server is inaccessible and will not do any backups during this upgrade.
Current version: 0
Target version: 0
In next 5 minutes I am able to login to the web page.
During this process I am able to use SSH and checked htop
. Nothing special, but swap is used
Is it problem with lack of free RAM ? If yes why full backup works correctly ?
