I’ve been experimenting with running a urbackup server on Centos 7, and so far so good. The backups are running fine.
But now i want to use this fancy mount button for the image backups. I’ve already installed the ntfs-3g package from EPEL and am now running the server as root which brought out the mount button.
Now i’m running a bit stuck though. When i push the mount button, it starts a few programs on the server:
/usr/bin/urbackup_mount_helper mount CTX-XENAPP 171207-1540_Image_C Image_C_171207-1540.vhdz
/usr/bin/urbackupsrv mount-vhd -f /share/BackupsNieuw/UrBackup/CTX-XENAPP/171207-1540_Image_C/Image_C_171207-1540.vhdz -m /share/BackupsNieuw/UrBackup/CTX-XENAPP/171207-1540_Image_C/contents -t /share/BackupsNieuw/UrBackup/CTX-XENAPP/171207-1540_Image_C/device -o uid=995,gid=992,allow_root --guestmount
This will keep running forever, the browser also stays loading all the time. Obviously not working.
Now if i manually use the command line to run the last command, all i see is:
Loading FUSE kernel module…
Starting VHD background process…
Waiting for background process to become available…
Which never continues, however, when i scale the command back to:
I get:
Mounting…
Mounted successfully.
I can also cd to the mount location and browse through the files. and do with them as I please. However when I re-add the -t (tempmount) parameter back it will be back to “Waiting for background process to become available…” all the time. same if I add the --guestmount parameter.
I can add the -o uid=995,gid=992 part, then it still mounts, but with -o uid=995,gid=992,allow_root I get the error: “fuse: ‘allow_other’ and ‘allow_root’ options are mutually exclusive”.
Is there anything I can do about this? It’s mounting fine, but not with all the paramters it wants to use, perhaps some settings can be changed somewhere?
