I don’t know if this may help others, but I had a problem recently while restoring an image via the restore CD. Image progress bar would indicate 100%, but then I received a report that it lost it’s connection to the server before completing restore. After trying several different options and still getting the same error, I refreshed the restore CD program’s network settings with a static IP. Image then restored without errors.
This image was small and DHCP lease time set much longer than the time to restore image. Not sure if this is a local network issue I need to investigate or not. If someone else has this issue and is under pressure to restore the image, I hope this helps.
And, maybe this is only a note to my future self when this happens again
