first of all, wow this is one of the most amazing things i seen for long time
I would like to help testing linux client. Is this possible?
best regards
Jörg
best regards
Jörg
There currently is no linux version sorry. There are some reasons for that:
That said it would not be difficult to create a linux version of the client. All code uses platform independent libraries. But for the time being I suggest you use backuppc as linux backup server. With enough interest or help an UrBackup client for linux (with less features) would be an option.
Hello, thank you for your response
i´m interessed in help for a linux client. also i had a lott of experience with different linux distribution.
but i´m not a programmer.
as additional information…
regarding the lvm thing. i found a programm that does “snapshot” of a normal ext3 file system. This snapshot is attached t o a virtual device.
Please have a look at: http://www.r1soft.com/tools/linux-hot-copy/
I don´t now what kind of mechanism they use, but it works very well.
so what could a linux client with less feature do?
I think there could be a possebilty to do a normal “tar” based file system backup including “mbr” and “partition info”. For bypass the database issue it could be an option to include a pre and post backup option? So the user is responsible to get his system in a known state, before starting the backup.
For a restore create the partition as described in the part.info file that is included in the backup, recover mbr and untar the file content to the “/” parttion.
finaly do things with chroot and grub-install …
I know that this is not same way as the solution that windows could provide… but maybe a workaround to have a possebility to create workstation images without having lvm installed …?..
if you would like me to test some things … i´ll be very glad to do this … because i like this handy tool …
