Per the docs: there should be a /var/urbackup folder but that folder doesn’t exist (when using shell for the jail).
Do you know the default UrBackup path for the FreeNAS plugin install?
What files should I use find
on to locate the folder path?
What other files should be in the folder where I’m installing the .url file?
