Hi All…
I’ve Tryed To Upgrade/Test The 1.5 UrBackup Server Beta But I’ve Lost My Original Key Since I’ve Removed The Server… And I’ve Not Read All The FAQ/Documentations Online (my fault I know)
Can Be Implemented A Way To Keep The Original .key .pub Files So If I Install A New Version Or I Reinstall The Older One The Server Can Reuse The Original Key Without Generate A Now One?
I Think About An Option In Setup/Installer:
[x] Use Found/Already Present Security Key
Or An Option On The Uninstaller Like:
[x] Keep Security Key For Reinstalling
Thanks…
